Timing Belt Help ASAP
Old Jan 27, 2011 | 10:31 AM
honda_ek9's Avatar
Default Timing Belt Help ASAP
So my timing belt snapped, when cranking the car. How can i tell if the vavles are bent or if I did any damage to the head or pistons? The "UP" on the camgears are facing the intake side (3/4) of the way, almost facing downwards.
If I was to do the timing belt how would i adjust the cams/gears to the right timing? Do i just turn it to were the "UP" is facing up with the two dots on the camgears line up? or do i have to throw on the timingbelt then turn everything to get it lined up? The exhaust cams is little off from the intake cams, just by alittle bit. Is it suppose to be like that when a timing blet snaps?
Read on how to replace timing belt but then my timing belt snap. so im clueless since mine snapped.
HELP ASAP. DOING THE TIMING BELT LATER 2NITE.
Thanks in Advance.
Old Jan 27, 2011 | 06:40 PM
mouab18c1's Avatar
Default Re: Timing Belt Help ASAP
Search and you'll find guides on how to install a timing belt.
Simply do a compression test once everything is back on properly, with bent valves a compression test would be able to confirm it.
Old Jan 27, 2011 | 07:33 PM
SolAssassin's Avatar
Thanks in Advance.
I can almost guarantee that you bent valves on the #3 cylinder. Hope that is not the case for you and I wish you a little luck.
Worst case scenario, if you did bend a valve, your car should still be driveable until you order some new valves, then you will have to take off the head and replace the valves, seals, and then do a valve lash. Go to hondatech.info and you will find just about every service manual there available for download
Old Jan 27, 2011 | 09:28 PM
mouab18c1's Avatar
I hope you are being sarcastic.
Old Jan 28, 2011 | 11:47 AM
Jmb106jr's Avatar
no he is being realistic. you will have bent valves. Thats why its called an interference engine. its not a matter if theres any damage just how much.
Old Jan 28, 2011 | 12:04 PM
mouab18c1's Avatar
You don't get it. It's okay to Drive with a bent valve? He must be dumb.
Old Jan 28, 2011 | 04:30 PM
fcm's Avatar
fcm
Old Fart
Don't just assume there is damage, you may be one of the lucky ones, install a new belt and see what happens. 94
Old Jan 29, 2011 | 04:59 PM
honda_ek9's Avatar
Alright guys got the timingbelt and water pump on. while doing it the waterpump only had 3 screws and 2 dowel pins. Replaced it with a oem gsr water pump but then the gsr water pump didnt have any dowel pins so i tried taking it off but wouldnt come or budge. so i just add an extra screw on. Would that secure the waterpump? the wholes where the dowel pins where in have some bolt patterns in them so i just installed a screw in one. but everything thing seems to be running pretty good. car started up right away. but i still gotta do the compression test. probably going to be doing it in a bit.
Old Jan 30, 2011 | 09:54 AM
fcm's Avatar
fcm
Old Fart
Sounds like you are one of the lucky ones, although massive damage can occur when timing belts break or even slip, [skip] on "interference engines" it is not always the case.
Definitely do the compression test, I would go as far as removing the head just so you can eyeball the piston tops and valve heads to make sure there is no minor damage, [nicks] that can develop into bigger problems later on. 94
Old Jan 30, 2011 | 02:55 PM
honda_ek9's Avatar
Hopefully im one of the lucky ones..but yea will have to do that..been busy..
Thanks guys for the help.
stevenDAtegra
May 7, 2009 09:56 PM
DETALZ
Aug 6, 2007 10:53 AM
ricebowl
Mar 3, 2006 07:41 PM
