ls/vtec wont idle right!!!
Old Feb 9, 2011 | 09:11 PM
ryan93eg's Avatar
Default ls/vtec wont idle right!!!
okay so heres the deal i got a 93 hatch with a b16 head and a b18a1 block, its all stock internals, its boosted on 6 psi, with a garrett super 60 turbo. i recently broke the tranny so i replaced it with a gsr tranny, this was my first tranny and i took the intake manifold off for some reason, so i dissconneced most alll the sensors, when i re assembold the engine i hooked all the sensors up to best of my knowledge, now the car will start but it has a shitty idle, about 500 rpm and it is running super rich. i checked all the vacume lines, i cleaned the iacv, and put a new plug in on the ckf sensor. and still no luck, i hooked a timing light up to it and it seems 180 off for the ignition timing because the timing mark on the crank pully was on the total opposite side. i try'd moving the dizzy but no change what so ever. need help!!!
Old Feb 9, 2011 | 09:33 PM
noender's Avatar
Default Re: ls/vtec wont idle right!!!
do you have the check engine light on?
Old Feb 9, 2011 | 09:37 PM
ryan93eg's Avatar
yes it is but it has always been on, cause its not the right engine for the car. not everything was done as it should (bought it ls/vtec already swaped) when the swaped the engine and harness
Old Feb 10, 2011 | 10:41 AM
chilango2004's Avatar
check you tps and map sensor plugs probably are backwards.
Old Feb 10, 2011 | 03:12 PM
ryan93eg's Avatar
i already checked the map sensor and there is two other plugs that look just like the map plug and i tryd every combination they could go on the tps and map but still no change?
dark_reverie
Aug 15, 2014 12:39 PM
275Performance
Jan 25, 2007 09:13 AM
turbociv
Jun 30, 2003 05:14 PM
DTAYLOR
Aug 15, 2002 08:37 AM
