91 DA B20B
Old Jan 29, 2011 | 07:42 PM
JDM-h22a's Avatar
Default 91 DA B20B
so i just got this integra has a b20b but something is going on with the battery or alternator and not sure of what the hell is going on so here it goes
so the first day i got it it started right up everytime no problems then the other day i was picking up my girl from school and then i unpluged her electric seatbelt before she got in ever since then the car doesnt hold a charge i have to jump it everytime now like i dont think its the alternator cuz the lights dont dim out or anything like that but when i drive and stop and turn the car off and then try and turn it right back on nothing just clicks and then the relay for the seat belts when its pluged in makes this weird whinning sound so i unplug it it doesnt whine anymore if anyone knows anything please pleasae let me know cuz i dont want to just go out and buy a new battery and then that one not work cuz of something else so please let me know thank you
Old Jan 29, 2011 | 08:04 PM
JDM-h22a's Avatar
Default Re: 91 DA B20B
come on someone has to know something of whats going on please
Old Jan 29, 2011 | 08:09 PM
netfreak's Avatar
You need to have your battery tested. If your power options don't work with the car off, it sounds like the battery is not holding any charge. You should also use punctuation.
Old Jan 29, 2011 | 08:12 PM
JDM-h22a's Avatar
ok. sorry just trying to get some advice quick.
so if i get the battery tested and it says it good then what should i look for???
Old Jan 29, 2011 | 09:07 PM
JDM-h22a's Avatar
thats all i get?? come on just need some info please..
Old Jan 30, 2011 | 10:33 AM
netfreak's Avatar
Probably check your fuses. I have no idea how the power seatbelt thing works but if it runs on an important circuit and the fuse blew, could lead to that sort of problem.
Old Jan 30, 2011 | 03:54 PM
mouab18c1's Avatar
Test your alternator. Loosen up the positive terminal on your battery, start the car and once it is on take off the positive terminal off your battery. With a weak alternator your car will die.
Old Jan 31, 2011 | 08:22 AM
JDM-h22a's Avatar
figurede out that problem old battery tested at only 10.7 volts supposed to be around 13 or 14... found out also that my map sensor was melted halfway gone and the plug a wire snapped loose so yea kinda sucks but whatever
kitsume
Apr 9, 2009 04:50 AM
caliek4
Apr 19, 2006 03:35 PM
samurablaze
Oct 27, 2005 05:02 PM
ridnmyhonda
Feb 16, 2003 03:06 PM
ace26
Apr 29, 2002 10:22 AM
