how to i set ignition timing without timing marks?
Old Feb 15, 2011 | 12:01 PM
thecorey's Avatar
Default how to i set ignition timing without timing marks?
when i bought my crx it had a b16 in it and it's missing the timing belt cover with the marks on it. it also has an aftermarket crank pulley that i can't seem to find any marks on either. what's the best way to set my timing?
Old Feb 15, 2011 | 12:51 PM
night's Avatar
Default Re: how to i set ignition timing without timing marks?
take out #1 plug, put a long screw driver on the piston and judge top dead the best you can then mark the crank/cover wherever you like with whiteout
Old Feb 15, 2011 | 12:54 PM
thecorey's Avatar
alright, so then i'll know where 0 degrees is. i guess it won't be possible to do it accurately huh?
i cleaned off the aftermarket crank pulley and found the marks then repainted them. then i set to TDC and made a mark on the side of the valve cover that lined up with the TDC mark on the pulley. jumped the service connector, started the car, then set the timing to my new mark on the valve cover. hopefully it's straight, i had to advance the distributor all the way to get it to line up with the mark i made.
can i do a lot of damage is it's advanced a little too much?
Old Feb 15, 2011 | 06:05 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Yes. B series motors are plentiful. Surely you can find a cover...
Old Feb 15, 2011 | 06:16 PM
2k.civic.si's Avatar
replace cover and get rid of the aftermarket crank pulley
Old Feb 15, 2011 | 07:29 PM
night's Avatar
u still need to put a screwdriver in and physically check TDC with the cam gears.
Old Feb 16, 2011 | 12:25 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
That will only ensure valve timing is correct. He is trying to set ignition timing.
Old Feb 16, 2011 | 05:31 AM
night's Avatar
Old Feb 20, 2011 | 05:12 PM
darkenedsol's Avatar
I would get a stock timing cover and a stock balancer, and set the timing. After it's set correctly, if you want you can swap the after market balancer on. Just my .02
Old Feb 20, 2011 | 07:22 PM
thecorey's Avatar
yeah i'm gonna get a timing cover this week. i ended up finding the marks on my crank pulley.
Old Feb 21, 2011 | 05:12 AM
kyden's Avatar
mark 0 degrees on the crank puley, then use an advance timing light.
londoncrx
Mar 6, 2011 06:30 PM
NSfit
Nov 26, 2006 07:34 PM
dsCRXsi
May 2, 2004 04:32 AM
OBD-One-Kanobe
Nov 1, 2002 09:21 AM
