B16 Swap Downpipe CX hatch
Old Feb 7, 2011 | 09:28 AM
Keenor's Avatar
Default B16 Swap Downpipe CX hatch
Planning on swapping a B16A2 soon into my CX hatch, but with the D16Y7 I think the cat is like on the downpipe? Whereas with the B16 the cat is located under the car is it not?
Old Feb 7, 2011 | 09:38 AM
kyden's Avatar
Default Re: B16 Swap Downpipe CX hatch
the stock cat is on the front of your motor, its one piece with the manifold.
Old Feb 7, 2011 | 09:47 AM
Keenor's Avatar
Right, and the manifold that came out of the SiR is obviously not this way.
Meaning what? I run no cat?
Old Feb 7, 2011 | 09:24 PM
Keenor's Avatar
Bump, has anyone done the swap with a Y7? How did you do your cat?
Old Feb 10, 2011 | 12:18 AM
maximusej6's Avatar
well, i have a ITR swap on my 98 DX (stock Y7) and when i did my swap i had to get a blox test pipe (cause the OEM ITR manifold is 2.5 collector and wouldnt bolt to exhaust) you are going to run into the problem of your B pipe being too long... you wont have anywhere to put a cat lol... unless you get an aftermarket exhaust that is meant to take one....
Old Feb 16, 2011 | 05:10 AM
Keenor's Avatar
My current "cat-back" is a little too short as it is, it's a stretch to clamp it down.
Can the Y7 cat just be relocated and welded underneath after the B16 downpipe?
I heard this cat doesn't flow as well as a DOHC vtec cat in the high RPM range?
Old Feb 16, 2011 | 08:43 AM
dpetro1's Avatar
i would suggest getting an aftermarket hi-flow cat and letting an exhaust shop cut/weld to fit. you may need to modify yout current cat-back as well. shouldn't be too expensive.
i don't think you will find a bolt-on solution since the header length/configuration is different between b-series and d-series motors.
Old Feb 16, 2011 | 08:53 AM
94EG8's Avatar
Seagull Management
Stock B16A manifold and downpipe + SiR cat + SiR midpipe + stock hatchback muffler = 100% bolt on exhaust.
Old Feb 16, 2011 | 09:01 AM
dpetro1's Avatar
lol true but i figure he will want to keep his current aftermarket cat-back
Old Feb 16, 2011 | 12:39 PM
Keenor's Avatar
I have, stock B16A2 manifold and downpipe, no SiR cat, no SiR midpipe, and my magnaflow "cat-back" which really just meets my downpipe I seem to remember..
Old Feb 16, 2011 | 01:54 PM
dpetro1's Avatar
again, with your current components you will most likely need a little custom work. get a highflow cat and have it mated up to the b16 header. some companies sell them with an adjustable flange so it can be positioned properly
egreenmachine
Apr 23, 2005 06:06 AM
TOTAL-TUNING
25
Mar 19, 2005 07:45 PM
StreetEG
Jan 9, 2005 04:44 PM
maxxd97
10
Oct 29, 2003 12:21 PM
2000CX
Jul 2, 2003 08:18 AM
