HELP Bolt extracting
Old Dec 12, 2012 | 03:59 PM
DC2Mex's Avatar
Default HELP Bolt extracting
I broke one of the bolts from the oil pump and i cant get it out. I tried drilling it out and using and extractor and broke the extractor inside the bolt. Im out of ideas on how to remove it. A friend said i can have it laser removed but not sure what this is. Anybody know how i can remove it or someplace i can take it and pay to have it removed. some where in socal.
Old Dec 12, 2012 | 05:55 PM
MikeM's Avatar
Default Re: HELP Bolt extracting
Use high quality cobalt reverse drill bits, start small take your time.
Old Dec 12, 2012 | 06:06 PM
DC2Mex's Avatar
I tried using a drill bit but it wont cut into the broken extractor thats already in the broken bolt. Would this cobalt drill bit be able to cut through the harder material of the broken extractor?
Old Dec 12, 2012 | 06:19 PM
MikeM's Avatar
What brand of bits are you using? Drill bits get dull, and they don't cut into the material properly. I have broken drill bits and extractors off, and was able to drill them out. I like using the reverse bits for this. Use a thin penetrating oil like WD40, let it soak in for a while before you start drilling. Try to keep the bit centered as well as you can.
Old Dec 12, 2012 | 06:30 PM
alphalanos's Avatar
you could also use a good center punch and punch a good hole in the middle, then the drill bit would stay in better
Old Dec 12, 2012 | 06:32 PM
Crx_owner_20's Avatar
ohhh man. I've done this and there was no success.. Try a small punch and hammer and see if you can work the bolt loose.. If not your bottom end is probably ruined.
Old Dec 12, 2012 | 06:38 PM
MikeM's Avatar
If you try to remove the broken bolt by chiseling it out, you will most likely do more damage. If your not sure, try a good local machine shop. It really doesn't look that bad, so don't stress about it.
Old Dec 12, 2012 | 06:51 PM
DC2Mex's Avatar
They were dewalt, not sure of the material, and yes most likely they are dull. I will try your method and see if i can get it out.
yes thats what i did
I hope not this is a full built benson sleeved laskey built block and spend alot of money. Im actually leaning towards paying someone to do it. I dont want to mess it up more than it already is. Anybody know about the laser removal?
Old Dec 12, 2012 | 07:10 PM
MikeM's Avatar
Frikken laser beams? That's above my skill level, I never head of this method.
joevtoo
Jul 3, 2014 04:45 PM
Mishako129
Aug 18, 2012 12:08 PM
maynards_ek
Dec 25, 2007 06:45 PM
a1320addict
Aug 26, 2006 05:19 PM
AndrewD
Jan 22, 2005 12:10 PM
