another usual idle prob..
Old Dec 19, 2012 | 10:56 PM
1FAMOUSDB8's Avatar
Default another usual idle prob..
well sold my db8 and now i have an ek with a b16, my prob. is that i cleaned out the throttle body cause it was pretty dirty and now when i turn it on it stays to 2000rpm and doesnt drop..any tips on i can doo..thanx for the help guys..
Old Dec 20, 2012 | 07:13 PM
go-part's Avatar
Default Re: another usual idle prob..
take off your fitv and and unbolt the two 8mm bolts you'll see a white screw plug use two screw drivers and tighten it down don't force it tighten it until snug, it can become loose overtime not closing properly after your car is warmed up during initial start up, causing a vacuum leak, also check to see if your iacv is clogged if it is clean it.
Old Dec 25, 2012 | 01:37 AM
foodstamp's Avatar
clean your ivac, worked for me on a 92 civic b7 doin same thing.
SuperSlowEF8
11
Sep 17, 2011 04:00 PM
lalocivic
Sep 7, 2009 01:03 PM
TegraD
May 15, 2009 02:55 PM
accord-lude
Feb 1, 2006 05:57 PM
alexb16hb
Oct 8, 2004 01:25 PM
