full blown dual pump fuel gauge problem help!!!!
Old Nov 25, 2012 | 04:23 PM
xbigpitax's Avatar
Default full blown dual pump fuel gauge problem help!!!!
i purchased a full blown dual pump kit and i installed it into my ek hatch wired it up to a relay and fuse everything thing works fine but my fuel gauge doesn't work anymore.... anyone know why this would happen or has this happened to any one?!?!?!
i used the search to find out if anyone had this problem but couldn't find anything, please help need this fixed
Old Nov 25, 2012 | 06:01 PM
xbigpitax's Avatar
Default Re: full blown dual pump fuel gauge problem help!!!!
anyone that is using this currently can you please post the way you have it wired thanks
Old Nov 25, 2012 | 06:21 PM
2xraeted's Avatar
i have the same prob with a 1996 gsr
Old Nov 25, 2012 | 06:25 PM
fullblown's Avatar
The oem hanger does not have a float valve attached to it. Are you guys sure you did not unplug the wrong harness?
You shouldn't have to touch the float valve when you install our pump hanger
Old Nov 25, 2012 | 06:41 PM
2xraeted's Avatar
well going to drop tank to check the float valve tomorrow
Old Nov 26, 2012 | 06:49 AM
xbigpitax's Avatar
im only doing the hanger side but when wirring up the pump do u use 1 relay or 2? i have mine on 2 and i think that might be it idk when i get home ill check the floater to make sure it good
Old Nov 26, 2012 | 04:57 PM
fcm's Avatar
fcm
Old Fart
MM&Y of car would help, an "EK" would make it a 95-98 RHD JDM Civic would it not, is it a RHD JDM Civic? 94
Old Dec 1, 2012 | 07:05 PM
Hondaguy83's Avatar
Check fuse, then wires n possible take it back out n mess with the list n see if the gauge moves.
xbigpitax
Nov 26, 2012 05:37 PM
CTR_B
May 24, 2009 02:20 PM
Wherm5150
Feb 3, 2009 07:26 PM
crxvtecred
Nov 29, 2005 03:40 PM
