2013 6 speed auto fluid level check
Old Dec 1, 2012 | 05:30 AM
hnd's Avatar
hnd
Default 2013 6 speed auto fluid level check
How do you check the trans fluid level on the 2013 Accord with V6 (6 speed auto)? Engine running or engine off?
Some cars must be in neitral, some in park, most cars with engine running, but this dip stick is so short, I'm afraid, it will spray out if i pull the dipstick with it running.
Old Dec 2, 2012 | 07:34 AM
hnd's Avatar
hnd
Default Re: 2013 6 speed auto fluid level check
Anyone know this procedure?
Old Dec 4, 2012 | 11:17 AM
jarnis's Avatar
My last two Hondas were designed to be checked with the engine off.
The manual says to take it to the dealer to have it checked. I wonder whether that's because people keep using other brands of transmission fluid which don't work correctly in Hondas. (I'm a stubborn "do-it-yourself" kind of guy who always learns the hard way; now I only use Honda brand transmission fluid, coolant, power steering fluid, and brake fluid in a Honda.)
-John
Old Dec 4, 2012 | 11:22 AM
hnd's Avatar
hnd
-John
Thanks John. I am like you, I do all I can myself and always use OEM parts and OEM trans, power steering fluids and coolant. Brake fluid and oil, I use my own choice (Mobil1 Synthetic oil, but in the OEM weight, 0W-20 and Valvoline Synthetic brake fluid).
I would rather than told you how to check the fluid rather than saying take it to your dealer....
Old Dec 12, 2012 | 01:26 PM
hnd's Avatar
hnd
deleted - had wrong info
Old Dec 15, 2012 | 08:37 AM
hnd's Avatar
hnd
So, does anyone have a 6 speed automatic Honda/Acura that has an owner's manual that has the steps to check the fluid level?
(the 2013 Accord's manual says to check with the dealer, but the dealer told me two different asnwers and so I want to see Honda documentation in this)
Old Dec 20, 2012 | 07:53 PM
swordofdoom's Avatar
You should check only after the car has warmed up to operating temp. Make sure its turned off first to get the correct reading and do a few readings like how you do your oil.
If your running low I suggest visiting a dealer and getting it refilled since sometimes they will do it for free especially if you bought it at their place and it could be due to a leak which would be repaired under warranty.
Coffey CupHonda
Jun 11, 2017 08:44 AM
HondaCRX1991
Mar 28, 2014 09:54 AM
trololog
Sep 22, 2013 06:04 AM
lucas1403
Mar 23, 2005 07:07 PM
shinra
Dec 25, 2002 08:59 PM
