Compression is 185, 170, 170, 210
Old Nov 4, 2012 | 06:12 PM
andyz's Avatar
Default Compression is 185, 170, 170, 210
D15b7 bone stock
What are likely problems given these numbers?
What are the simplest cheapest tests that will narrow down the problem more?
Old Nov 4, 2012 | 06:13 PM
hybridmiklo's Avatar
Default Re: Compression is 185, 170, 170, 210
mileage, leakdown tester to see where the air is passing by.
Old Nov 4, 2012 | 08:20 PM
rrace002's Avatar
Did you just build it?
Old Nov 4, 2012 | 08:21 PM
rrace002's Avatar
Or make any changes, did you just acquire it.... A little background info....
Old Nov 4, 2012 | 10:28 PM
UncleD's Avatar
What else could be bad besides rings and valve seals/guides?
Old Nov 5, 2012 | 06:34 AM
andyz's Avatar
I think the harbor freight leakdown tester is junk. The reviews say it will only regulate the output pressure up to 25 psi. How much should I pay for a Decent tester?
How do I hold the crank in position? Does it have to be at absolute TDC? I had compressed air at 90 psi pumped in and on some cylinders i think it started to slip the power steering belt, which I was trying to use the ps pump pulley bolt to lodge a wrench against the subframe.
If it is just past tdc by 10 degrees or so, what is the difference? Ring lands?!
It's still definitely on power stroke with no valves open, I can clearly see th cam and rockers....
300,000 mi. Smokes a little at high revs in driveway. Block test was negative for combustion gases.
Sometimes feels like losing power. New plugs helped.
185, 170, 170, 210.
Pattern is very consistent. Did it several times, cold warm, seven stroke crank, 12 strokes crank...numbers vary, but overall pattern is evident
Old Nov 6, 2012 | 04:08 PM
rrace002's Avatar
Isn't 210 a little high for a d series?
Old Nov 7, 2012 | 02:14 PM
andyz's Avatar
What's that about....all cylinders have carbon on top...3 and 4 spark plugs show a lot of ashy deposits...., but 3 is 170. Weird
Can oil control problems raise compression?
Old Nov 7, 2012 | 05:37 PM
james0429's Avatar
you can try a wet compression test , a cap of oil into the cyl . if your compression goes up after this test, you have faulty rings not sealing completely ... or you can do a leak down test which will give you an exact problem. To hold the crank in position you want to get it at TDC COMPRESSION and do not try to hold it , if your off a couple of degrees the pressure will force your rod/piston down hence making the crank rotate. take your breaker bar off . You want exhaust and intake valves completely clossed. you can double check this with a coat hanger seeing the piston is at the top of travel or like you said the rocker/cams... good luck!!
Old Nov 8, 2012 | 04:51 AM
andyz's Avatar
So if I put the regulator for the compressor on the END of my hose, hold the power steering pulley with my 19mm open end, I should be able to slowly turn up the pressure, while moving the crank back and forth a couple of degrees until I can keep turning up the pressure, but the pressure is going straight down into a completely vertical connecting rod?
And then let go of the power steering pulley? Wow. It's like I think that if someone walks by and whispers , the crank will move enough to get leverage on the 1* of the crank and then push itself over rapidly and highly dangerously.
Can I just put the car in gear instead?
Mechatronics
Mar 14, 2013 04:59 PM
crxhondarx7
Feb 1, 2008 02:39 PM
chibiko
Feb 11, 2007 05:45 PM
awps
Aug 13, 2005 03:53 PM
Slammed2K1
Dec 5, 2003 07:35 PM
