GSR starting and running problem?!?!
Old Dec 17, 2012 | 08:40 PM
HX35_Ek_Hatch's Avatar
Default GSR starting and running problem?!?!
Ok so I just rebuilt my 1997 civic with a gsr swap and it gave me the 6 code which is the crankshaft position sensor, I bought one but the plugin doesnt match any of them, It wont rev past 5k and it starts hard but runs fine until 5k then it like sputters no matter how much gas you give it, do you think the wiring harness could have the stock ek civic plug in or what, do you even need the CPS? Any thoughts?
Old Dec 18, 2012 | 01:24 PM
LS/VKEV's Avatar
Default Re: GSR starting and running problem?!?!
First thing, whatever shop did your engine swap, take your ride back. It might be you need a new wiring harness or an upgraded CPU or something else.
Old Dec 18, 2012 | 01:29 PM
Fliptard's Avatar
does it have the stock GSR intake manifold? That mani has extra plugs for the secondary butterfly valves in the intake that a stock Civic harness does not have, also are you running an OBD1 or 2 ecu and Distributor?
Old Dec 18, 2012 | 03:39 PM
I bought the car swapped and I rebuilt it and now its giving me code 4 and 6 cel code and no the intake mani isnt stock and the ecu was tuned by Dkgoodrich in kentucky, i think its the crankshaft speed sensor in the distributor not the one on the oil pump because i dont think it ever had one. It has a OBD1 ecu and i think obd1 distributor. My ecu says p06 and my distributor button says p06 but the actual coil says p08 lol
Old Dec 22, 2012 | 09:10 AM
Update, bought a new dizzy and its a obd2 dizzy but now it is missing and will barley start.....
Old Dec 22, 2012 | 09:31 AM
grumblemarc's Avatar
The Grumpiest
It has to be throwing a CEL. What is it?
Old Dec 22, 2012 | 03:45 PM
Hondaguy83's Avatar
Need to give more info. What ecu, wire harness??
Old Dec 23, 2012 | 09:17 AM
stephen.forbes1's Avatar
need more info on this im waiting for my 97 to come back from shop with 00 GSR swap would have done the swap myself but i live in cali
Old Dec 30, 2012 | 06:38 PM
Has a p06 obd1 ecu and a obd2 wiring hArness And its throwing 4 and 6 code on my cel.
Old Dec 30, 2012 | 11:58 PM
Hondaguy83's Avatar
The piggy harness that had wiring problem
Old Dec 31, 2012 | 09:14 AM
Never heard of a piggy harness. What is it.
Old Jan 4, 2013 | 06:44 PM
Hondaguy83's Avatar
How did u plug your obd1 ecu in if it had obd2 connectors?
Old Jan 5, 2013 | 11:59 AM
h22speed's Avatar
confusing
Old Jan 7, 2013 | 08:59 AM
outage's Avatar
Did you check your fuel injectors?
Old Jan 7, 2013 | 06:28 PM
pluging the OBD1 system in to a OBD2 connector is the easy part you just do what i did and get a track harness and jump it thru that to the ecu you just have to know what your doing when you do it
Old Jan 8, 2013 | 06:55 PM
My injectors are good and all u need is a 0BD2 to 0BD1 converter from the harness to the ecu....there like $75
go-fast_integra
10
Oct 26, 2010 09:03 PM
Mr. EF
Feb 27, 2009 09:23 AM
b18eric
Nov 11, 2008 09:54 AM
