Gsr ef sedan
Old Oct 14, 2021 | 04:20 PM
Jdarriola's Avatar
Default Gsr ef sedan
I have a 1990 EF sedan with a gsr b18c1 I just recently rebuilt motor new piston rings rod bearings main bearings head gasket come to find out a torque wrench I used was broken so I over tightened everything I didn't know that I started it it died a couple times then blew all the oil out of back of the block I took the motor out losing everything backup got a new torque wrench put everything down to spec put the motor back in fight last night started first try van for about 45 seconds no smoke no knocking then shut off went to look and it did it again the oil on the ground through the hole in the back of the block where the catch can goes in please help
Old Oct 14, 2021 | 10:24 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Gsr ef sedan
Remove the catch can and plug the hole.
Old Oct 14, 2021 | 10:52 PM
Jdarriola's Avatar
How an what about the presure that biulds up in the block ??
Old Oct 15, 2021 | 07:51 AM
iwannarace's Avatar
Do you mean the OE oil breather box, or is it an aftermarket catch can?
There is a vent in the valve cover to exhaust crankcase pressure. For emissions it gets sucked into the intake. I have mine exhaust to open air cuz race car.
Old Oct 15, 2021 | 08:51 PM
JRCivic1's Avatar
10 Year Member
Community Builder
What about it ??? If you are building a NA GSR engine... it is nothing to worry about. It is installed on a stock engine for emissions, not because the engine makes "too much crank-case pressure".
SIty808
19
Jul 10, 2011 04:43 PM
Yell0w
Feb 15, 2009 03:27 PM
pouponu
Dec 25, 2008 03:40 PM
MlnknprkrM
Jun 1, 2004 08:21 PM
SuperCivic
Jul 30, 2002 07:09 PM
