suggestions after timing belt replacemnt
Old Jan 9, 2023 | 01:04 PM
micparks's Avatar
Default suggestions after timing belt replacemnt
Hey gang, need some suggestions. Im an old head that had a em1 back in 2k. I recently bought a 05 d17 that had a snapped timing belt when i bought it. Got the car real cheap and planned on using it as a cheap commuter car instead of my gas guzzling truck.
Long story short is i recently finished the timing belt replacement, new plugs, water pump, tensioner etc. When i try to start the car i get what seems to be a slow crank like the battery is dying. Its a brand new battery and its charged etc so thats not the issue it just cranks slow like the battery is dying. Im going to double check the timing this weekend, but IF the timing was off a tooth or so would the car start and run like **** or would it not start at all? Im pretty mechanically inclined I just havent touched a honda in about 15 years. I will also be checking fuel and spark but what are some other things I should check? It ran before the belt snapped so nothing else "should" be wrong but I want to cover all my basis. TIA
Old Jan 9, 2023 | 01:40 PM
Ryanthegreat1's Avatar
Default Re: suggestions after timing belt replacemnt
Probably missed some ground wires between engine and body.
Or it could be a failing starter.
Or dirty battery terminals.
stranded3
Honda Civic (2001 - 2005)
Oct 14, 2017 08:58 AM
sickofitall1113
Nov 23, 2006 09:39 PM
valve79
Dec 29, 2004 03:20 AM
specv5150
11
Oct 7, 2004 02:39 PM
amb4081
Mar 2, 2004 11:20 AM
