AC Troubleshooting
Old Jan 17, 2023 | 11:35 AM
zerovandez's Avatar
Default AC Troubleshooting
The low side oring/seal on the AC compressor went bad so I replaced it. Im now trying to recharge the system but running into a vacuum issue. Vacuum doesnt seem to go beyond 27inHG on the low side gauge. The high side gauge doesnt appear to attempt to drop at all. As soon as I close the valves on manifold, my Vacuum starts to drop back to 0 on the low side. Here is what I have tried.
1. Replace the schrader core on both low and high service ports.
2. Test vacuum on the manifold - connect both service valves to storage ports and ran vacuum. No vac leaks and held for a few hours.
3. Closed the service valves while vacuum was connected and running - drops straight to 29-30inHg without vac leaks. I think its safe to assume that my manifold is good.
4. I can partially fill the system with r134a. No leaks at all. I can even charge it to the point where the compressor turns on.
So the system holds pressure but not vacuum. What else should I be doing and where else should I be looking?
flanker
39
Mar 25, 2015 08:56 PM
NightmareTA
Jun 2, 2012 10:20 AM
blacktibby07
16
Mar 5, 2011 05:50 PM
RHD EG H2B
21
Jun 27, 2009 11:51 AM
littledan
Mar 18, 2005 03:10 PM
