GSR No spark
Old Dec 1, 2021 | 02:03 PM
MastaFlyMason's Avatar
Default GSR No spark
I have a 96 GSR and I'm trying to diagnose a no spark issue. It has an S300 with P28 ECU as well as the Burton Racing coil on plug kit but I tried with the stock distributor with the same results. Fuel pump primes, and check engine light does as it should. I am getting power to IGP1 and IGP2 at the ECU and I checked the grounds at the ECU as well. The distributor is getting 12v (I believe the blk/yel) I have a good valve cover ground, a good trans ground, my thermostat wires are properly grounded, the the COP kit is grounded to the back of the distributor. I did have the car completely gutted and I'm wondering if there is something behind the dash I could have missed. Also the car had a security system (OEM), I wasn't sure if this would cut spark or how it worked. The shock tower plugs are all hooked up. I've been pulling my hair out trying to figure it out and I'm stumped. Any suggestions?
Old Dec 1, 2021 | 02:39 PM
Default Re: GSR No spark
edit: disregard this
Old Dec 2, 2021 | 06:07 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
What was your problem ?
Old Dec 3, 2021 | 01:32 PM
I pulled out the engine harness and while it looked untampered with I pulled back the sheathing and found some splices and one had come loose. I replaced the engine harness and all is well
Old Dec 3, 2021 | 09:24 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Thank you for the response.
StreetDreamS808
12
Oct 13, 2014 07:28 PM
forcefedh22
Nov 19, 2012 11:29 AM
GoSickemRobert
Engine Management and Tuning
Aug 3, 2011 11:07 AM
j4yzn
Aug 24, 2009 12:45 PM
Takumi Fujiwara
Jun 15, 2004 06:49 AM
