Problems with JUN flywheel eating my starter!
Old Nov 30, 2001 | 12:58 PM
B19CivicHB's Avatar
Default Problems with JUN flywheel eating my starter!
Will I run into this problem if i put in my JUN lightened flywheel? I got a piece of paper with it mentioning something about the gear of the starter not aligning properly with the teeth on the flywheel... anyone know about this?
Old Nov 30, 2001 | 01:27 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Problems with JUN flywheel eating my starter! (B18CivicHB)
Yea, I've heard of it before.
Don't know what to do, but it's pretty common I guess.
Old Nov 30, 2001 | 03:00 PM
B19CivicHB's Avatar
Default Re: Problems with JUN flywheel eating my starter! (B18C-EJ1)
anyone know how to fix it?
Old Nov 30, 2001 | 08:10 PM
Def's Avatar
Def
It's caused by high grade steel contacting high grade steel. This type of steel is more brittle than the mild steel used in the stock flywheel. Whenever you have two types of brittle metal rubbing against each other, they just tend to eat each other up in short time. Aluminum flywheels don't suffer from this(aluminum = much softer than steel).
Only way to "minimize" the risk of this is to make sure everything is aligned dead-on.
Old Nov 30, 2001 | 08:37 PM
Katman's Avatar
I've heard of this problem from people on Hybrid and I don't have any suggestions for you but one thing....
Don't believe the LIE that you need a JDM starter.... it's total BS. That stupid rumor was getting thrown around the hybrid board - a JDM b-series starter is no different than its US counterpart.
....just letting you know if someone ever tosses that line at ya
[Modified by Katman, 9:38 PM 11/30/2001]
Old Nov 30, 2001 | 09:13 PM
B19CivicHB's Avatar
Default Re: Problems with JUN flywheel eating my starter! (Katman)
ha thanks for the heads up! I guess ill just have to throw it in and hope for the best!
Old Nov 30, 2001 | 09:47 PM
earl's Avatar
Look at the teeth on the ring gear of your Jun flywheel. Are they square cut on both sides or is the leading edge bevel cut? The leading edge of the teeth must be bevel cut to match the teeth on your starter (which are bevel cut). The reason Jun's have problems is because some come with straight cut teeth. Those are the ones that tear up your starter. There is no problem with the type or hardness of the metal of either gear. I heard you can actually take a grinder and cut bevels on the flywheel teeth if you have a straight cut gear but make sure you ONLY do the leading edge.
Old Nov 30, 2001 | 10:39 PM
quick108's Avatar
Default Re: Problems with JUN flywheel eating my starter! (earl)
I'd say it only happens a quarter of the time. Todd from JUN USA told me there are different tolerances with the DENSO starters. Who knows...
I'd install the flywheel first. You'll know pretty much right off the bat if you have the problem b/c you'll hear a high pitched grind when you turn the flywheel over.
It happened to me, but it is easy to fix. Just take a small grinder, like a dremel, and bevel the gear teeth slightly on your starter (you might be able to see shiny metal where the flywheel is contacting the starter). GOOD LUCK!
-JP
Old Dec 1, 2001 | 12:21 PM
89civicdx's Avatar
Default Re: Problems with JUN flywheel eating my starter! (quick108)
I have used one of their flywheels for 2 years with no probs and I never touched the starter.
Old Dec 1, 2001 | 12:38 PM
B19CivicHB's Avatar
Thanks for the info guys, im gunna go ahead and throw it in to see how it does.
Old Dec 2, 2001 | 12:55 AM
koy's Avatar
koy
New User
-JP
yep, that's it
leboeuf45
May 13, 2004 07:48 AM
accordfreak
Oct 29, 2003 03:00 PM
SpoolnG2
Jan 20, 2003 04:24 PM
MrBui
Dec 23, 2002 10:29 AM
quick108
Jul 13, 2002 02:18 PM
