lsd? (limited slip)
Old Nov 29, 2001 | 08:36 AM
mr2's Avatar
mr2
Default lsd? (limited slip)
any of you tech head have a webpage to tell me how lsd exactly works?
Old Nov 29, 2001 | 09:23 AM
Lsos's Avatar
Default Re: lsd? (white eg)
Good luck man.
It took me a long time to understand how an open differential works, and it's still not sunk in all the way.
I've seen diagrams, write ups, explanations.....I don't think anybody truly understood it, they were just regurgitating information.
Anyways, if you truly figure it out, props to you. If anyone can explain it in a way that others can understand, props to you too.
Old Nov 29, 2001 | 10:46 AM
Safir's Avatar
hrmm someone wants to know how something works... try http://www.howstuffworks.com... they have a very good article on differentials here: http://www.howstuffworks.com/differential.htm
Old Nov 29, 2001 | 11:49 AM
3.3.3's Avatar
Default Re: lsd? (Safir)
tiiite.b16a.com
Old Nov 29, 2001 | 12:48 PM
mr2's Avatar
mr2
Default Re: lsd? (maks)
thanks
Old Nov 29, 2001 | 12:50 PM
Jim S. '95 Z28's Avatar
In overly simplified terms, and LSD is nothing more than a spring-loaded clutch pack. The wheel with greater rotational velocity loads springs mounted between the side gears via a clutch coupling. The springs then expand, exerting pressure on the opposing clutch pack, effectively transferring torque to the other side gear/wheel.
Imagine subjecting a slinky to torsional stress. To unload/relieve the tension, the slinky will expand. Now picture clutch units attached to side gears on each end
[Modified by Jim S. '95 Z28, 9:52 PM 11/29/2001]
Old Nov 29, 2001 | 01:01 PM
mr2's Avatar
mr2
Default Re: lsd? (Jim S. '95 Z28)
I got the general idea thanks
Old Nov 29, 2001 | 01:37 PM
No prob
Old Nov 29, 2001 | 02:08 PM
Lsos's Avatar
Aaaahhhh......but what about the gear LSD'd, like the Quaife?
That's what I was referring to. The howstuffworks article gave a very half-assed explanation of it.
Old Nov 29, 2001 | 03:04 PM
Default Re: lsd? (Lsos)
What's a "gear" LSD?
There are several different methods to achieve "positive traction:"
- Standard limited slip units, either clutch of cone style
- Spools
- Lockers
Old Dec 4, 2001 | 11:34 AM
Honda_HatchEG's Avatar
well with LSD say you lunch at a light or track and you burn out sometimes only one tire well burn out and soemtimes both tires well burn out. but with LSD it grabs every time so if you ever decide to go track racing get it because if you **** going into a corner and only on wheel grabs you well lose or it will be harder to control so with LSD it easier to handle and helps you all around. hope this helps
Old Dec 4, 2001 | 02:51 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: lsd? (Honda_HatchEG)
your post made no sense at all.
Youlose1305
Jul 4, 2006 09:13 AM
fjt
Dec 7, 2005 06:32 AM
KFBhonda
Mar 4, 2005 02:48 PM
Digger 5
Feb 12, 2004 11:07 AM
Pfieff
Oct 10, 2003 09:15 AM
