How hard is it to install...
Old Nov 30, 2001 | 10:04 AM
Cyrio's Avatar
Default How hard is it to install...
Skunk2 Coilovers, Tokico Illumnas, and a camber kit?
Are there any sites explaining this process?
Old Nov 30, 2001 | 10:33 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: How hard is it to install... (Cyrio)
very easy.
Old Nov 30, 2001 | 10:38 AM
Crazydave's Avatar
Default Re: How hard is it to install... (B18C-EJ1)
easy to do all at once
Old Nov 30, 2001 | 10:43 AM
sackdz's Avatar
Default Re: How hard is it to install... (Crazydave)
A roll of tin foil and some wire will go about 500 miles before a hole burns through it.
EDIT - It appears I have replied to the wrong thread. LoL. sorry.
[Modified by sackdz, 3:43 PM 11/30/2001]
Old Nov 30, 2001 | 10:55 AM
Cyrio's Avatar
Do you need a spring compressor?
Old Nov 30, 2001 | 11:31 AM
Greyout's Avatar
you do to get the stock ones out, but depending on the springs you probably don't to get the new ones in, at least in the front.
Old Nov 30, 2001 | 02:36 PM
martini's Avatar
Default Re: How hard is it to install... (JDM LUDE)
You can do it without a spring compressor, it just takes a little abstract thinking. You unbolt the top while it's still on the car, and under weight, then you jack the car up, and unbolt the rest of the stuff. You are basically using the cars weight as your spring compressor.
Old Nov 30, 2001 | 02:38 PM
Crazydave's Avatar
Air tools make it reall easy.. you need a spring compressor..
and then you need to have the alignment done....
oops I forgot.. you need the upper ball joint transfered to your new Upper control arms..
thats probably something you can't do....
hmmm
Old Nov 30, 2001 | 10:03 PM
Cyrio's Avatar
thanks
jrivehard
Suspension & Brakes
22
Dec 16, 2008 09:26 PM
ityab0y
Suspension & Brakes
12
Jan 6, 2005 09:37 AM
All_JDM_Si
Sep 29, 2003 11:00 PM
TrueZen
Dec 18, 2002 12:12 AM
95si
Oct 11, 2002 07:16 PM
