TPS Sensor Problem --- Please Help!!
Old Dec 4, 2001 | 12:03 PM
NeXtLeVeL_TyPe_R's Avatar
Default TPS Sensor Problem --- Please Help!!
I recently installed a Ericks racing TB
My TPS sensor is set to close to specs .5 closed 4.7 open with engine off
when it is fully open my VAFC will read 100 % throttle position
Now when i turn my engine on the TPS sensor readings are like .005 closed and barely reach 4 volts open and the kick in the butt is that the VAFC reads only like 88% throttle position.
I know my TB is opening all the way mechanically but it seems like there is some sort of electrical problem tahts screwing with my ecu and telling it that i am only on the throttle 88% when i am trying to put the pedal threw the firewall
This is bothering me greatly becuase it seems like i am losing power
Anyone have any suggestions?
Also i have a very annoying idle problem that has uncovered no leaks off any sort can this be attributed to the TPS too?
_______
NeXtLeVeL_TyPe_R
Mar 20, 2005 12:19 PM
TeknikDC2
Mar 6, 2005 06:30 PM
98gsrTEG
Apr 17, 2004 11:12 AM
low-tech assassin
Nov 6, 2003 10:43 PM
Smashback
Dec 16, 2001 06:37 PM
