something is wrong with my breaks?? PLEASE HELP!!!!!!
Old Dec 4, 2001 | 09:50 AM
integra81's Avatar
New User
Default something is wrong with my breaks?? PLEASE HELP!!!!!!
can someone tell me whats wrong with my breaks?? most of the time they work fine. but every once and a while it seems like there loose. when i hit the break pedal it goes almost all the way to the floor before the breaks start to slow down the car. then i let go of the break and there back to normal. this doesnt happen often almost like once a day but its pretty scary when you hit the break and noting happens when it should. any one know what this could be, i was thinkin maybe there could be air in the breaking lines or someting?
Old Dec 4, 2001 | 09:51 AM
Crazydave's Avatar
Default Re: something is wrong with my breaks?? PLEASE HELP!!!!!! (integra81)
bleed them..
also check your pads....
Old Dec 4, 2001 | 09:57 AM
keithv's Avatar
Default Re: something is wrong with my breaks?? PLEASE HELP!!!!!! (Crazydave)
You probably have air in the system and need to bleed the brakes like Crazydave said...
Old Dec 4, 2001 | 08:49 PM
9integra2's Avatar
New User
Default Re: something is wrong with my breaks?? PLEASE HELP!!!!!! (breaka_1_9)
A common sympton on the 90-93 integras. The common solution seems to be replacing the master cylinder because it has an internal leak.
reddigitaldragon
May 13, 2003 10:38 AM
91int
Feb 22, 2002 11:23 PM
integra81
Dec 4, 2001 04:06 PM
integra81
Dec 4, 2001 02:34 PM
integra81
Dec 4, 2001 11:44 AM
