Idle too high...
Old Nov 29, 2001 | 02:45 PM
SjCiViCHB's Avatar
Default Idle too high...
Okay, my car is really idling high, its idling at 2000 rpms. i dunno why its doing that, i tried adjusting the idel screw and still the same, and i tried adjusting the throttle cable too and it still stays the same....help mee....
Old Nov 29, 2001 | 02:49 PM
Rice_Boy's Avatar
Default Re: Idle too high... (SjCiViCHB)
im not a mechanic, but try resetting ecu? just a suggestion, im new to this!
rice_boy
Old Nov 29, 2001 | 03:47 PM
rioninja's Avatar
First thing, pull of your intake tube and visually check that your throttle plate is closeing all the way. If it is, and your not throwing any codes, its probably the fast idle thermo valve (think thats the name). also, did it happen all of a sudden?
Old Nov 29, 2001 | 05:28 PM
BreakStuff's Avatar
New User
A vacuum leak is a major cause of a high idle, especially when the engine is cold and first started.....
Old Nov 29, 2001 | 08:37 PM
SjCiViCHB's Avatar
Default Re: Idle too high... (BreakStuff)
yeah i was thinking its a vaccumm leak tooo, imma try tightening all the bolts again tommrow, and make sure all the hoses are on tight. And would starting a cold engine have anything to do with it? because its been two days since i started the car with the new throttlebody.
Old Nov 29, 2001 | 08:39 PM
SjCiViCHB's Avatar
Default Re: Idle too high... (RioNinja)
hmm, can i see if theres a big gap? cause it looks like its closed all the way, also wheres the fast idle thermo valve at? and yeah this just happen after i installed my new throttle body. but i am throwing a code, im throwing a MAP sensor code, but ive had that code before even installing the new throttle body but it was fine before i installed the new throttlebody.
[Modified by SjCiViCHB, 5:41 AM 11/30/2001]
Old Nov 29, 2001 | 08:46 PM
rioninja's Avatar
The thermo valve is the part directly connected to the bottom of your throttle body, that has the cooland lines going into it. you can try swapping the one from your other TB, if all else fails.
Old Nov 29, 2001 | 08:49 PM
SjCiViCHB's Avatar
actually thats what i did, the throttlebody didnt comethe bottom part so i had to use the one from my old t.b.
Old Nov 29, 2001 | 08:52 PM
rioninja's Avatar
make sure that all the o-rings are in there, also you -did- try adjusting the idle screw right?
Old Nov 29, 2001 | 09:20 PM
civic_sir94's Avatar
New User
one of my friends had that problem, it turned out to be a loose wire under the accelerator...but that was just him
Old Nov 30, 2001 | 12:17 AM
Lyonel's Avatar
Try this http://www.lyonel.8m.com/adjidle.htm
Old Nov 30, 2001 | 01:34 AM
SjCiViCHB's Avatar
yeah i tried adjusting the idel screw already. Thanks for the other suggestions guys. ill look into it tommrow. Oh, one more thing, When the car revs to like 3000, it back fires and when the revs drops, it sounds like the engine is going to die at first but then just stays on idling really high.
Old Nov 30, 2001 | 07:58 PM
BreakStuff's Avatar
New User
I think that might be a normal condition for a confused ecu (backfire)...
when the car is cold.. ecu controls idle, except ecu cannot see a vacuum leak creating a high idle situation..
you hear of people saying that their idles fluctuates when the car is warm.. this is due to the ecu giving the motor control of the idle, except the motor cannot accomplish this due to various reasons/problems unknown to the ecu, the ecu will try to compensate for the problem "hunting" for the proper idle causing a fluctuation...
now you say your idle is high when cold???, thats when the ecu controls idle..
check vacuum leaks by spraying carb cleaner around intake hoses and gaskets while the car is running and see if the idle goes even higher...this would be a sure sign of a vacuum leak..
Check coolant level..
Check coolant temp sensor and intake air temp sensors for proper values...
[Modified by BreakStuff, 12:00 AM 12/1/2001]
[Modified by BreakStuff, 12:01 AM 12/1/2001]
Old Dec 1, 2001 | 01:45 AM
SjCiViCHB's Avatar
Thanks for all the help guys, i got the car fixed now, along with the other codes the ecu was throwing tooo. YES! it was the wiring to the ecu that was causing it to go badd...Thanks again guys. Peace.
maitlenclan
Nov 9, 2013 04:27 PM
b20bFourDoorCivicLX
Aug 8, 2012 09:58 PM
90Rexx
Jul 2, 2008 08:53 AM
jetlude
Jul 31, 2006 06:12 PM
RedStarGsr
Jan 7, 2004 12:01 PM
