Rod/Stroke D16's
Old Nov 27, 2001 | 10:07 AM
Spade's Avatar
Default Rod/Stroke D16's
Where the hell does anyone find information on the POS D16's.
Sleeper mode.......bore and sleeve a D16.....maybe
Old Nov 27, 2001 | 12:07 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Rod/Stroke D16's (Spade)
75mm bore x 90 mm stroke
Old Nov 27, 2001 | 12:09 PM
Spade's Avatar
Default Re: Rod/Stroke D16's (Mista Bone)
Hrm, so my guess is a 1.6 SOHC has a very poor r/s if a 1.6 DOHC has 6 more mm on the bore.
Old Nov 27, 2001 | 01:12 PM
Spade's Avatar
R/S ratio on a Stock D16 is 1.52:1
Stroke is 3.54"
Rod is 5.39"
I have a project on my hands don't I All you DOHC suckers better watch out.....it will be ready in about 6 years!!!!
Old Nov 27, 2001 | 01:57 PM
smp534's Avatar
New User
look into doing a mini me setup
also look into Gude, R&D and Atomic Performance, thay have all done 11 sec D16's!!!!(streetable)
Old Nov 27, 2001 | 11:36 PM
Mista Bone's Avatar
D Tranny Guru
D15 non vtec has 1.59 RS ratio
D15 VTEC has 1.63 rs ratio
Understand why I wanna build a long stroke 1.5L VTEC (basically VTi)?
Old Nov 28, 2001 | 12:20 AM
SjCiViCHB's Avatar
yup. use the D15B7 block, its better then the D16Z6, and add a D16Z6 head on the D15 block and you can build a really strong motor.
Old Nov 28, 2001 | 06:15 AM
Spade's Avatar
Default Re: Rod/Stroke D16's (smp534)
What is a mini me setup
I know for a fact I want to increase the deck height. So I can "stroke" then engine....purpose is a better R/S ratio. So basically I am going to have to rebuild the block anyway Want to hear the good part? D16Y5.....yup VTEC-E! I can always swap the head to a VTEC and of course I want to be the fastest HX.
Edit: BTW do any of those sites have a webpage that you know of?
[Modified by Spade, 3:16 PM 11/28/2001]
Old Nov 28, 2001 | 07:14 PM
Spade's Avatar
DAMMIT.....okay....D16 has a 90mm stroke with like a 137mm rod.....increasing the rod lengh also increases the stroke......i just realized this.....Sigh, I need to find a way to keep stroke some what normal (close to 90 and get the damn rod lenght up).......a rod lenght of 157mm on a 90mm stroke is perfect however, it won't work with a D16 Crank. Fudge!
Old Nov 29, 2001 | 03:53 AM
Mista Bone's Avatar
D Tranny Guru
Why you think ENDYN went with a custom crank in his destroked 1.6L (1.55L)?
Old Nov 29, 2001 | 08:01 AM
Spade's Avatar
Okay.....if I increase rod lengh keeping the same crank I would need to have rods of XXX lengh to cover it basically stroking the hell out of the block.
My goal is a 100mm stroke that I will bore to 81mm. 2060cc!!!
[Modified by Spade, 5:05 PM 11/29/2001]
Old Nov 29, 2001 | 08:03 AM
HXMan's Avatar
Increasing rod length will not increase stroke. It will increase dwell time at TDC and BDC. Also it leads to less extreme rod angles in relation to the crank, which results in less sidewall loading.
I belive a d15 motor is just a d16 block containing a crank with a shorter stroke, allowing the use of longer rods.
Old Nov 29, 2001 | 08:08 AM
Spade's Avatar
Default Re: Rod/Stroke D16's (HXMan)
Thnx HXMan,
I will be researching the D15 crank. But, are you saying the stroke is only effected by crank size and not rod!?!
Old Nov 29, 2001 | 08:17 AM
HXMan's Avatar
Yes, rod length does not affect stroke length. Take a b16b(CTR)for example. It is a b18c block, with a b16 crank, and longer rods, resulting in 1.6 liters of displacement. It has a r/s ratio around 2.x I belive. Good for prolonged high rpm use and power.
Old Nov 29, 2001 | 08:26 AM
Spade's Avatar
Hmm, guess I might have to go with custom crank and rods.
Old Nov 29, 2001 | 01:41 PM
Mista Bone's Avatar
D Tranny Guru
Blocks are different. Main journals are smaller and the deck height is lower on 1.5L's.
Old Nov 29, 2001 | 02:23 PM
Spade's Avatar
Okay....do ya know if the valve springs are swappable? See some aftermarket valve spring for a Z6 and want to put them on the Y8.
Old Nov 30, 2001 | 02:58 AM
Mista Bone's Avatar
D Tranny Guru
what cam are you gonna run?
Old Nov 30, 2001 | 06:05 AM
Spade's Avatar
For now I am going to stay with the stock cam.....I plan on slowly building the car......springs and retainers, valves and guides, then port and polish, then cam.
After the head work is done I will go to the bottom end which I am looking into the sleeve and bore....want 81mm.
Old Nov 30, 2001 | 08:50 PM
Mista Bone's Avatar
D Tranny Guru
putting springs on now will kill power.
Wait till you get the cam.
Old Dec 1, 2001 | 06:07 AM
Spade's Avatar
Hmmm, guess I am just gonna have to do the whole head at once then......
Oh well.
WhiteyW/AHonda
Sep 11, 2011 04:49 PM
805_Slow_Master_93EG
27
Apr 29, 2008 11:17 AM
big-cat
14
Nov 6, 2007 04:01 PM
JDMTuner4Life
Feb 24, 2007 07:29 AM
Jun 20, 2004 04:53 PM
