Throw Out Bearing?
Old Dec 1, 2001 | 10:59 AM
bahkhok's Avatar
Default Throw Out Bearing?
This morning when I go to start my car I press the clutch in to start it up. When I push down on the pedal at about middle of the pedal travel I hear this ticking sound. It happens either depressing or pressing down. Ist his the throw out bearing? It never made this noise up until this morning. Is just the unnormaily cold weather possible cause of this? What is the worse can happen with a noisy t.o bearing?
Old Dec 1, 2001 | 06:12 PM
BreakStuff's Avatar
New User
Default Re: Throw Out Bearing? (bahkhok)
Sure it isnt the spring on the clutch pedal making the noise? these things have the exact symptoms you describe and especially when the weather gets colder...
Old Dec 1, 2001 | 06:24 PM
bahkhok's Avatar
Default Re: Throw Out Bearing? (BreakStuff)
Yup becasue I can hear the ticking coming from the trans housing.
Old Dec 1, 2001 | 09:25 PM
BreakStuff's Avatar
New User
Could be the springs in the clutch disc "chattering"
throw out bearings make a low groan/humming noise when bad/dry..
the previous owner of my car installed an aftermarket clutch and my clutch disc springs chatter very similiar to the sound of a valve clatter... that clatter is the springs on the disc assy.. does it cause any harm?? not unless one of those springs break.. I don't worry about it ...
95BG33PGSR
Jul 19, 2011 03:22 AM
93accordEX
Feb 2, 2010 04:40 AM
gofastgokart99
Sep 27, 2007 01:42 PM
s2kkk
Honda S2000
14
Jan 28, 2006 07:54 PM
Cereal_Killer
20
Nov 2, 2002 10:00 AM
