How to cut fuel?
Old Nov 27, 2001 | 05:25 PM
Teal95Coupe's Avatar
Default How to cut fuel?
How can you cut fuel on a B16? I looked in the fuse box and there wasnt a fuse for it. Thats the way I know so what are other ways?
Old Nov 27, 2001 | 05:32 PM
Jared's Avatar
Default Re: How to cut fuel? (Kyoko-Chan)
How do you want to cut fuel? What exactly are you trying to accomplish?
Old Nov 27, 2001 | 05:33 PM
Default Re: How to cut fuel? (Jared)
compression test
Old Nov 27, 2001 | 06:43 PM
VitaminVTEC's Avatar
Can you unplug the injectors on your car?
Old Nov 27, 2001 | 06:47 PM
rainforest's Avatar
Default Re: How to cut fuel? (VitaminVTEC)
fuel pump should have a fuse pull that.
Old Nov 27, 2001 | 11:20 PM
Mista Bone's Avatar
D Tranny Guru
Pull the ECU fuse in the underhood fuse box. Sometimes labeled as "backup"
Old Nov 28, 2001 | 07:53 PM
vhd's Avatar
vhd
on hondas you have to disconnect the connector to the fuel pump, lift up the rear seat and you should see a cover with about three screws, remove that cover and there should be two connectors, one for the sending unit and one for the fuel pump, disconnect the two and you will cut off the fuel
m.glisson003
Oct 31, 2011 05:53 PM
Rainmaker
May 10, 2007 11:17 AM
NoDestinationSi
Mar 16, 2005 02:35 PM
Matgallis
Mar 9, 2005 11:31 PM
prelude_boi
Apr 21, 2002 08:11 PM
