straight pipe question
Old Nov 27, 2001 | 11:08 AM
jdmrealm's Avatar
New User
Default straight pipe question
I have a straight pipe from the header (stock) to my muffler (stock)...What am I gaining and losing? And how would that compare with me having a carsound or some other "high flow" cat?
Old Nov 27, 2001 | 12:06 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: straight pipe question (4g63turbo)
Gain = noise, pollution, in car fumes.......
Loss = a little torque below say 3500 rpm.
Now if you decide to spray, run the test pipe! I picked up .35 in the 1/4 mile just buy using a $10 test pipe made from parts at Autozone.
14.05 to 13.70 on a SOHC
Old Nov 27, 2001 | 03:12 PM
sloaccord96's Avatar
Default Re: straight pipe question (Mista Bone)
in car fumes?? explain please, i'm thinking of eliminating my cat and putting in a straight pipe myself...help thanks, lost of torque? gain of hp?
Old Nov 27, 2001 | 03:15 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: straight pipe question (sloaccord96)
By removing the cat your polluting more emissions into our air. The gains are not worth it.
Old Nov 27, 2001 | 03:17 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: straight pipe question (B18C-EJ1)
Less restriction, frees up HP, but in turn, polutes the world. Chances are you won't pass inspection w/out a cat.
Old Nov 27, 2001 | 04:41 PM
Default Re: straight pipe question (ForcedAccord)
can't i just put the cat back when i go take a smog test? and put the pipe in in the raceway?
Old Nov 27, 2001 | 04:42 PM
hey you go a turbo for your car? how do i get a turbo for a 5th gen V6??
Old Nov 27, 2001 | 06:09 PM
SBR*EG4's Avatar
in a stock equipped cx the straight pipe only made power in your head due to the sound and like everyone else said is putting more **** in our environment!
Old Nov 27, 2001 | 11:22 PM
Mista Bone's Avatar
D Tranny Guru
with drivers window down about 1/3, the exhaust flows back in through the open window. With the cat on, you don't smell it.
Nothing like showing up for a date smelling like exhaust.
Old Nov 28, 2001 | 04:21 AM
Texas B*tch!
SloAccord, build it custom.
Old Nov 28, 2001 | 07:36 AM
Kalokohan's Avatar
New User
It's not worth it in an N/A car but it has some gains on a turbo application. You will pass inspection unless the guy inspecting it looks under your car. You will definitlely fail emissions though unless you put it back on.
Old Nov 28, 2001 | 11:42 AM
Katman's Avatar
**disclaimer** for offroad use only***
you can run a resonated straight pipe. It's basically a glass-pack in place of your cat. Running one will cut down on the loud ricey sound levels & at the same time free up exhaust flow restriction.
Some people say that running a str8 pipe is useless on a naturally aspirated engine (all motor), I beg to differ..
Old Dec 10, 2001 | 01:21 PM
jdmrealm's Avatar
New User
Default Re: straight pipe question (Katman)
I just recently had to get a smog check so I went and got a bolt-on high flow cat...I dont know if people speak from experience when they say on n/a its useless but they are wrong...After I put the cat on..the car was not only slower...but also more sluggish..not as responsive...took it back off after the smog check...you can actually feel the diff in pull and responsiveness.
PurpleAccord88
Feb 3, 2007 08:32 PM
aemintgsr
Jan 10, 2005 12:18 PM
99AccordTurbo
Jun 11, 2004 10:26 PM
808State
May 14, 2002 11:12 AM
00PurpleGSR
Apr 13, 2002 03:29 PM
