Steering Rack?
Old Nov 26, 2001 | 05:53 PM
Screamer's Avatar
Default Steering Rack?
What are the ratios of the following steering racks?
Integra Type R
Integra GSR
92-95 civic dx (power steering)
92-95 civic cx (no power steering)
Also will the integra rack fit in the civic?
Thanx for the help.
Old Nov 26, 2001 | 06:05 PM
EPGONZALEZ's Avatar
Default Re: Steering Rack? (Screamer)
hehe..i like the way you think..wish i had the answers..im curious myself
Old Nov 26, 2001 | 07:39 PM
hondura's Avatar
dont know the ratios off the top of my head. But they are in the order you put it in (Best to worst).
Yes it will fit in a civic.
Old Nov 26, 2001 | 07:54 PM
drumsy's Avatar
New User
Integra Type R
Integra GSR
Thanx for the help.
Err......my 95 Civic DX Coupe was not equipped with P/S. Rather it was rack & pinion. Did some 5th Gen DX's come equipped??
Old Nov 27, 2001 | 03:11 AM
Screamer's Avatar
Default Re: Steering Rack? (drumsy)
Yes the once in Canada did come with the p/s.
Old Nov 27, 2001 | 03:15 AM
Screamer's Avatar
Anyone else know the ratios?
Another question I have is is there a kit that converts the p/s rack to a manual rack? I guess it would be a catch can and a couple of houses to return the fluid. Anyone any ideas what could be used for the catchcan, besides a used engine oil container.
Old Nov 27, 2001 | 09:49 AM
Lsos's Avatar
Just plug up the hydraulic lines with bolts like I did, or attach them to each other in a loop.
Old Nov 27, 2001 | 12:24 PM
Spade's Avatar
Civic p/s 17:1
Civic non 19:1
Teg p/s 16.1:1
Old Nov 27, 2001 | 01:34 PM
Screamer's Avatar
Default Re: Steering Rack? (Spade)
Are you saying that the Type R and the GSR has the same ratio?
Old Nov 27, 2001 | 01:36 PM
Spade's Avatar
My guess.....yup. But I don't know.
Old Nov 27, 2001 | 01:54 PM
siisgood00's Avatar
New User
pretty sure type R and GSR have same ratio.
Old Nov 28, 2001 | 08:40 AM
Screamer's Avatar
Default Re: Steering Rack? (siisgood00)
Anyone else knows for sure?
Old Nov 28, 2001 | 11:37 AM
Katman's Avatar
yep..
all of the 94+ integra r+p are the same ratios.
I actually tried an integra r+p in my civic, it was cool for a while but I got sick of it.
It installed nicely & everything, the turning ratio was cool, I would only turn the wheel approx. 2.5 turns to the right & about 2 turns leftwise and the wheels would be fully turned either way.
What I got sick of was this...
There's this one certain street I would always make a left-hand U-turn on when I had my civic r+p on. I could pull a U-turn on this street no problem. After swapping over to the integra r+p (I got an alignment once I installed it too), I went back to the same street and did my usual U-turn...turns out I had to do 3 point U-turn. It sucked because I found out why too. The integra r+p, turning all the way to LEFT, doesn't actually go all the way like a civic r+p does - which sucks! But on the otherhand, turning all way to the RIGHT was fine and matched that of a civic r+p.
It's weird, I dunno why they made the integra r+p like that, but it irritated the hell outta me whenever I made left hand sharp turns or U-turns.
I eventually went back to my civic r+p, I like it a whole lot more.
..just my experience with an integra rack & pinion.
Old Nov 29, 2001 | 07:50 AM
Screamer's Avatar
Default Re: Steering Rack? (Katman)
Thank you for your honest opinion, Katman.
How different was the driving when on the track was the steering more responsive?
Old Nov 29, 2001 | 09:09 AM
Katman's Avatar
heh, I didnt get a chance to test it out on the track. sorry...
Old Dec 14, 2001 | 02:46 PM
Eggman's Avatar
did you try it with the PS or without? trying to figure something out...
Old Dec 16, 2001 | 03:39 PM
Katman's Avatar
Default Re: Steering Rack? (Eggman)
without...but I used a resivour tank to keep the rack loobed with P/S fluid. That didnt work out too well ....it would leak and get all over my engine bay. another reason why i took out the integra r/p.
testify
Suspension & Brakes
Jun 13, 2013 08:09 PM
PARADOX_sf
30
Mar 17, 2009 10:54 AM
stiness101
Jul 7, 2006 07:40 PM
