ECU wiring
Old Mar 13, 2002 | 03:31 PM
r30slick's Avatar
Default ECU wiring
Im putting a d16z6 vtec head on my friends 89 CRX Si... He has the P28 ECU from the a d16z6. As you probably know the d16a6 harness doesn't fit the P28 ECU. What is the best and cheapest way to hook this up? Is it possible to just buy the d16z6 harness adapters (the plugs that go in to the ECU) and plug the d16a6 wires into the new plugs. If so does anyone have some sort of diagram. Remember I need Vtec to activate.
to my friend getting his SR20DET in his 240sx. I know its not but its still sweet.
Old Mar 13, 2002 | 04:51 PM
Katman's Avatar
Default Re: ECU wiring (r30slick)
well one thing you c a n try is this:
- retain your friends 89 Si distributor and somehow mickey mouse it to stay on the Z6 head.
- get a hold of JDM PR3 B16A ECU and have it reprogrammed (I guess by me, since I seem to be the only one with mugen PR3 program with a few disabled sensors).
Converting an 88-91 EF to obd1 is kind of a bitch if you don't know how to do it. It's easiest to leave your car NOBD, and get a NOBD VTEC ecu (PR3).
Old Mar 13, 2002 | 06:54 PM
rainforest's Avatar
Default Re: ECU wiring (Katman)
that or rev swich from msd or zdyne 1 wire. pwn3d
Old Mar 13, 2002 | 07:15 PM
r30slick's Avatar
I thought the Zdyne is only for the B16 swap
Old Mar 13, 2002 | 07:45 PM
rainforest's Avatar
yep. hey make them so yougive them your stock then use like a internal relay to set the vtec.
Old Mar 14, 2002 | 10:59 AM
Katman's Avatar
Default Re: ECU wiring (rainforest)
that or rev swich from msd....
the problem with an RPM activator switch route is that you're still stuck with the lame fuel/timing maps of a non-vtec ecu...
Stanceman
11
Dec 7, 2017 10:02 PM
fickster
16
Jul 30, 2015 02:03 AM
1sickeg8
Dec 4, 2009 10:07 AM
TehMoonRulz
Apr 4, 2005 06:38 PM
