CRANK PULLEY BOLT
Old Mar 17, 2002 | 07:15 AM
importneeds's Avatar
Default CRANK PULLEY BOLT
IS THERE A EASY WAY TO TAKE THE CRANK PULLEY BOLT OFF?
Old Mar 17, 2002 | 07:24 AM
DragII's Avatar
25 Year Member
Default Re: CRANK PULLEY BOLT (importneeds)
yes, it involves an impact gun, and turning off the caps lock on your keyboard.
Old Mar 17, 2002 | 08:25 AM
Erik_Pb_Foot's Avatar
New User
Default Re: CRANK PULLEY BOLT (SuperDragII)
lol
Impact gun and if that isn't enough, get a torch (acedeline works best, can't spell, but you know what I mean) or other REALLY HOT torch and heat it until it glows red. Then hit it with the gun while it's glowing. if those aren't options, then a BIG pipe over your craftsmen ratchet and torque the hell out of it. I would highly suggest the torch/air method though
Old Mar 17, 2002 | 12:19 PM
xcivic_ex
Guest
Posts: n/a
Default Re: CRANK PULLEY BOLT (Pb_Foot)
Honda has a crank pulley tool.. it has a hexagon head that fits inside of the actual pulley.. and you use a nice big 3/8 ratchet with long handle and pull both the "special tool" and the ratchet together.. might need some big muscles though those things can be a bitch
Old Mar 17, 2002 | 01:17 PM
EE_Chris's Avatar
Default Re: CRANK PULLEY BOLT (xcivic_ex)
https://honda-tech.com/zerothread?id=145043
This thread should help you out.
Old Mar 17, 2002 | 01:23 PM
Ri5e's Avatar
Default Re: CRANK PULLEY BOLT (EE_Chris)
If the motor is in the car:
Put it into gear, and push down on the brakes.
Have another person with a 3+ feet long bar on the 2 feet breaker bar and give it one instant "quick" thrust. It should break loose.
Old Mar 17, 2002 | 04:20 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: CRANK PULLEY BOLT (BG Boost)
You can do it the ghetto way like I did. My motor was out of the car though. Have two friends stand on the block, get a nice big Craftman/SnapOn ratchet with a nice long pipe on the end of it. Jab a screwdriver into one of the holes in the flywheel and break that sucker off!
It's loud when it finally does come off. Good luck.
bradley
13
Jan 9, 2012 02:12 PM
Baron55
Mar 2, 2007 11:00 AM
grngsr01
Oct 23, 2005 05:47 AM
SuicideSlide
Oct 9, 2004 08:27 AM
TrueZen
Feb 27, 2004 07:42 AM
