which eagle rods for a b17a?
Old Mar 13, 2002 | 01:18 PM
Brian_92GSR's Avatar
New User
Default which eagle rods for a b17a?
Which rods would go into a b17a? Are they unique, or are they shared with a different engine as well?
Old Mar 13, 2002 | 01:21 PM
non-VTEC's Avatar
Default Re: which eagle rods for a b17a? (Brian_92GSR)
they will be the exact same rods as used in the B16 engine.
Old Mar 13, 2002 | 01:29 PM
New User
Default Re: which eagle rods for a b17a? (non-VTEC)
Are all pistons the same, aside from the bore? I've got wiseco pistons from endyn and eagle rods from importparts. I'm putting the lower end together and the pistons protrude about .15" from the deck at TDC. It's a b17a resleeved to 84.5mm
Old Mar 13, 2002 | 01:40 PM
non-VTEC's Avatar
all the B-series engines have the same cylinder bore. 81mm the only thing diffrent from the 1.6L to the 1.8L is the stroke
you better double check the part numbers on the rods you have and call up endyn to make sure they sent you the right pistons. it should not stick out the top of deck at all.......
Old Mar 13, 2002 | 01:45 PM
sgT's Avatar
sgT
No. b17a rods are specific to b17a.
Old Mar 13, 2002 | 01:47 PM
New User
Default Re: which eagle rods for a b17a? (sgT)
Do you know who all makes rods for the b17a? Here is the listing at importparts:
Eagle ESP H-Beam Rods 1.8 Integra B18A/B18B/B17A1/B20 (Set of 4)
Can you confirm that this is wrong before I call Ben?
Old Mar 13, 2002 | 01:50 PM
non-VTEC's Avatar
oops........sgt is right........the B17 has a diffent rod than the B16.
crower makes rods.........you might want to compare them to the eagles.
specs from crower website:
Acura Integra 1.7 VTEC DOHC (B17A 1992-93) 5.208" 1.890" 0.935" 0.826" (21mm) 0.900"
Integra 1.8 non VTEC DOHC (B18A/B18B 1990-up) 5.394" 1.890" 0.935" 0.826" (21mm) 0.900"
looks like you got the Integra LS rods which are slightly longer........return them and get the proper ones........
[Modified by non-VTEC, 5:52 PM 3/13/2002]
Old Mar 13, 2002 | 01:57 PM
sgT's Avatar
sgT
b16a rod is also longer than b17a rod
Old Mar 13, 2002 | 02:31 PM
New User
Unfortuantely I'm not getting any help from importparts, just the number to someone at Eagle.
I've already got all of the pistons connected to the rods. They are free floating and have little rings that snap into a groove to hold the piston pin in place. I can't imagine it being very easy to get that ring back out, and advice before I try?
Old Mar 13, 2002 | 03:43 PM
non-VTEC's Avatar
it shouldent be that difficult to remove the snap rings.........you cant remove them with a needle nose plyers and a small screw driver?
that's probably what i would use even though it's probably not the right tool........
Old Mar 13, 2002 | 06:56 PM
rainforest's Avatar
yeah man the b17a's ahve totally diffenrent rods 131mm not 134 like the b16a. pwn3d
takata_nsxr
Mid-Atlantic (Sales)
Mar 23, 2014 03:14 PM
GORILLARILLA21
Aug 26, 2010 09:52 PM
quik sol
Aug 20, 2004 08:07 AM
queez
Jun 24, 2003 06:43 PM
GoldenONE
May 19, 2002 12:05 PM
