setting the ignition timing
Old Mar 14, 2002 | 07:20 AM
fsp31's Avatar
Default setting the ignition timing
Ignorant question alert...
When I am facing the engine bay (distributor on left), which direction is advance vs. retard? I'm thinking that if I rotate the distributor "away" from the front of the car, this is timing advance. Is that correct??? Thanks for the help.
Old Mar 14, 2002 | 07:39 AM
bojangs's Avatar
New User
Default Re: setting the ignition timing (fsp31)
push the distributor back toward the firewall to advance it.. opposite to retard..
Old Mar 14, 2002 | 07:55 AM
EE_Chris's Avatar
And since you didn't know which way to turn the distributor, you probably don't know to short the Service Check Connector under the dash before setting the ignition timing....so make sure to do that too.
A Helms manual (for your car and transplanted engine) works wonders here.
Old Mar 15, 2002 | 03:52 AM
kkim's Avatar
Default Re: setting the ignition timing (EE_Chris)
also, use a timing light.
Old Mar 15, 2002 | 07:52 AM
fsp31's Avatar
>>A Helms manual (for your car and transplanted engine) works wonders here.<<
Yep, I've got the factory manual. That's why my question was kinda lame . I thought I was going crazy, but as I advanced the timing, low-end was getting worse. But the issue turned out to be ecu related. I'm not crazy after all!
Old Mar 15, 2002 | 07:19 PM
phildeez's Avatar
where is the service check connector?
Old Mar 15, 2002 | 07:36 PM
kkim's Avatar
Default Re: setting the ignition timing (phildeez)
try this site...
http://www.c-speedracing.com/howto/timing/timing.html
prodjay10
11
Mar 28, 2015 09:07 PM
chieftaco
Nov 3, 2009 12:33 PM
thedudefromjerz
Apr 26, 2007 09:57 PM
Ek00fbp
Mar 15, 2004 11:45 AM
H23ludedude
Feb 11, 2003 11:12 AM
