Fuel Pressure
Old Mar 14, 2002 | 10:47 AM
JMX's Avatar
JMX
Default Fuel Pressure
ok i have a LS i/h/e will boosting the fuel pressure do me any good in the HP department, ie a quicker 1/4 mile run
if so what it stock and what should i go up to
[Modified by jmx2323, 7:48 PM 3/14/2002]
Old Mar 14, 2002 | 02:11 PM
tinkerbell's Avatar
Default Re: Fuel Pressure (jmx2323)
i really dont think so...
stock should be around 40psi with vacuum hose removed.
Old Mar 14, 2002 | 06:49 PM
JMX's Avatar
JMX
Default Re: Fuel Pressure (tinkerbell)
i did some research and stock should be between 40 and 49, but upping it i dont know what that will do wiht what i have....probably nothing but i juts got a B&M for free so hell why not put it on
Old Mar 14, 2002 | 06:52 PM
tinkerbell's Avatar
whoah whoah!
no no!
unless you can measue your fuel pressure, dont put the B&M one on!!!!!!!!!!!!!
if you got it free, buy the B&M gauge and do it properly!
you wont be able to set FP at ALL!
thats why not.
t..
Old Mar 14, 2002 | 06:57 PM
StorminMatt's Avatar
It might help a little bit. But if i/h/e is all you dod, it probably won't help much. And listen to what the other guy said. DON'T use an adjustable FPR without some way of knowing exactly what the fuel pressure is. In fact, the proper way to start off using an adjustable FPR is to first measure the stock fuel pressure to know where to begin. Then add the adjustable fuel pressure regulator and start at stock pressure. The B&M gauge is inexpensive and easy to add.
Old Mar 14, 2002 | 08:57 PM
JMX's Avatar
JMX
Default Re: Fuel Pressure (StorminMatt)
ok yeah definatly, my dad has a gague bot filter mounted thouhg, but i will probably get the gauge, they run like 35 bucks i think
but the question is, if bumping it up will help even a little, what to i bump it up to above 49 btu what does anybody elese run
[Modified by jmx2323, 5:58 AM 3/15/2002]
Old Mar 14, 2002 | 09:01 PM
tinkerbell's Avatar
i have a K&N filter and a close to stock exhaust (cat-back)
i run 42psi, which is close to stock.
turning it up doesnt help uintill you have more *airflow* through the engine...
with i/h/e maybe 44 to 46psi in a B16A is cool...
(sorry i dont know your engine etc...)
t..
Old Mar 14, 2002 | 09:52 PM
GSG2's Avatar
t..
are these fuel pressure numbers with the vacuum hose attached?
Old Mar 14, 2002 | 11:25 PM
tinkerbell's Avatar
Default Re: Fuel Pressure (jobau)
of course.
how else do you measure it?
Old Mar 15, 2002 | 06:29 AM
JMX's Avatar
JMX
i have a LS b18b
Old Mar 15, 2002 | 09:53 AM
GSG2's Avatar
of course.
thanks bro. i was asking because when u take off the vacuum hose of the FPR the FPgauge reads a higher pressure than the reading with the hose attached. now i know u based the numbers when the hose is attached. thanks
blackeg
Apr 14, 2007 06:23 AM
Mr.EM1
Jan 6, 2005 11:17 AM
TegLove
Mar 29, 2004 05:06 PM
phthalo
Jul 9, 2003 06:58 AM
RaVAGE00
Jun 9, 2002 07:58 PM
