Need help!!!! Quick!!!!
Old Mar 15, 2002 | 03:36 PM
mantic6t9's Avatar
Default Need help!!!! Quick!!!!
Ok so i'm drive home from my local shop it's about 15miles from my house. I get off the interstate and stop at the red light at the end of the off ramp. While i'm sitting there i hear a strage noise but it went away. By the time i got to my house it sounded like my engine was demolishing it's self. I poped the hood and started the car and it's coming from my distributer. I'm guessing the bearing have gone bad. Anyone know of a good place to get a distributor? Also will a d16y distributor work in a d16z engine? If you can give me any info it would cool, is it hard to install a new one?
Old Mar 15, 2002 | 03:45 PM
StyleTEG's Avatar
Default Re: Need help!!!! Quick!!!! (mantic6t9)
Open up the distributor cap and see if there are any metal shavings inside.
That would be a good sign its crapping out.
I would consider get a distributor from a salvage yard, they can be pretty pricey from the dealer.
On integras replacing the distributor is pretty easy. Unbolt it, unplug the electrical harness, remove the rotor and cap. Then do the reverse with the new distributor.
Set the timming and then you are done.
My guess is it should be similar for your engine.
Old Mar 15, 2002 | 03:52 PM
mantic6t9's Avatar
Default Re: Need help!!!! Quick!!!! (StyleTEG)
I just recently did a valve adjustment, could this relate to the distributor?
[Modified by mantic6t9, 12:53 AM 3/16/2002]
Old Mar 15, 2002 | 05:58 PM
mantic6t9's Avatar
Anyone else? Someone on here must have replaces a distributor before. THe noise im hearing is like a grinding noise.
Old Mar 15, 2002 | 10:01 PM
mantic6t9's Avatar
TTT is this for sure what's wrong, are there any other possibilities?
Old Mar 16, 2002 | 08:11 AM
StyleTEG's Avatar
Like I said, pull off the distributor cap. If the distributor is grinding it will leave metal shavings inside the cap. If this is the case, replace
Old Mar 16, 2002 | 02:35 PM
tonyxcom's Avatar
The bearing is probably froze or dry so it makes hella noise when it turns, but it may not be loose enough to grind the rotor on the inside of the cap.
same thing happened to my buddy a while back. Gang load of noise. To check, pull the distributor and try to spin the rotor. If you cant....time for new distro
Old Mar 16, 2002 | 05:29 PM
mantic6t9's Avatar
Default Re: Need help!!!! Quick!!!! (tonyxcom)
well i hear a new one is around $400 should i get a new one of try and find a used one? I mean damn i can buy a new d16 for $500-600.
Old Mar 16, 2002 | 05:33 PM
Evil_Wizard's Avatar
I got a good distributor from a 93 si. Just did a motor swap on my brothers car. So I have a spare distributor laying around if you need one. Make me an offer.
Old Mar 17, 2002 | 08:45 AM
mantic6t9's Avatar
Default Re: Need help!!!! Quick!!!! (Extreme_Hybrid_Hatch)
Ok i'll keep that in mind. What do i need to do to make sure i don't get shocked while messing with all this stuff?
Old Mar 17, 2002 | 12:14 PM
fastestdriver's Avatar
Distributor bearings go out all the time. See bunches of them at the dealership.
If you get the wrong dist. it will cause you problems...yes it may bolt in and start but the timing will be way off and will not have any power. And just because aftermarket parts store says it's right doens't mean it is. Have fought this many times.
Old Mar 17, 2002 | 12:17 PM
Jeef's Avatar
easiest way to make sure you don't get shocked or burn something up when working on the engine is simply removing the neg. batt. cable...
Juan_Mitosis
Mar 2, 2009 02:04 PM
Go_Kart_Driver
Apr 17, 2007 01:28 PM
Touch
Mar 10, 2003 12:56 AM
RAWB
Jan 3, 2003 08:31 AM
