no more BS how do I reprogram LS OBD2 ECU
Old Mar 13, 2002 | 10:19 PM
OneThirtyEight's Avatar
Default no more BS how do I reprogram LS OBD2 ECU
ok I have an LS (thats right NO VTEC people) I have almost every possible engine modification available for it. Now my ECU doesnt like this, and I need to raise my redline to 8k rpm. How can I do this with my existing ECU does anyone reprogram OBD2 ecu's?
Old Mar 13, 2002 | 11:23 PM
BlackOutSi's Avatar
Default Re: no more BS how do I reprogram LS OBD2 ECU (97blackteg)
From what I've heard, the ODB-II ECU's have the rom and the microprocessor in the same chip. That's why it's so hard to reprogram them.. But, I have heard that Hondata is close to cracking the OBD-II programs, so I'd expect to see something within the next 6 months from them.
Best bet is to go with OBD-I ECU and harness, and get Hondata.
Old Mar 14, 2002 | 08:11 AM
Daemione's Avatar
Yeah, as of now, no one can reprogram the OBDII chips. Best option is to swap for an OBDI, and use a Hondata. An alternative would be a piggy-back system, like the AFC.
Just curious, why the need for such a high redline? Without VTEC or some fairly radical cams, you're not going to be making much power up there.
Old Mar 14, 2002 | 09:28 AM
Katman's Avatar
try hitting up G-Force. they can reprogram OBD2 ecu's, but it's not gonna be under $200. So have some $$ ready.
oh woops..i guess G-force isn't around anymore....check it out
http://www.gforceengineering.com/home.html
crazy..
Old Mar 14, 2002 | 04:43 PM
Rboosted717's Avatar
dynospot can do the OBD2 ecu. They have been doing it for a while, except for the price, most seem to be going with the hondata because they are also a dealer for hondata.
Old Mar 14, 2002 | 05:38 PM
non-VTEC's Avatar
if you dont mind sending your ECU to canada Yosio from japanese automotive is a Techtom ECU programmer and one of the best ECU tuners in the world. (so i've heard) they do OBD2 ECU's but are pretty expensive.
http://www.japanese-auto.com/
vbspec
Aug 9, 2008 06:40 AM
wesley_925
Engine Management and Tuning
May 15, 2008 05:11 PM
Mugencrxsir1
Mar 15, 2006 10:35 PM
Pompiuses
Dec 4, 2005 12:43 PM
integranator
Mar 2, 2003 09:45 AM
