i found the problem!!! timing belt
Old Mar 13, 2002 | 04:46 AM
B18C-RnVA's Avatar
New User
Default i found the problem!!! timing belt
well after taking Jareds advice i looked at my timing...the belt has a big *** tear right in the middle of it. and it even put a little hole on my valve cover( the part thats over the cam gears) so i guess ill have to get a new timing belt is there anything else i should replace.
dam i hope i didnt bend the valves..please dont be bent..i was wondering is there anyway i can tell if the valves are bent before putting on the timing belt.
[Modified by B18C-RnVA, 2:52 PM 3/13/2002]
Old Mar 13, 2002 | 06:04 AM
Spade's Avatar
Default Re: i found the problem!!! timing belt (B18C-RnVA)
Water pump.
Edit: I mean you should also replace the water pump since you have to basically tear everything off of the engine.
[Modified by Spade, 7:04 AM 3/13/2002]
Old Mar 13, 2002 | 07:56 AM
EE_Chris's Avatar
Default Re: i found the problem!!! timing belt (Spade)
Perhaps the tensioner set should be replaced as well.
And I usually use a new crankshaft pulley bolt too.
Old Mar 13, 2002 | 10:32 AM
Quik Chris's Avatar
Default Re: i found the problem!!! timing belt (EE_Chris)
The only way I really know to check if the valves are bent is a compression test, or take the head off the car, poor some water or any liquid (within reason) into the ports, let it sit on it's side, then check back in a day to see if they're leaking. But that's kind of an intensive process...
Shaw14
38
Aug 25, 2009 07:27 PM
lilskud13
14
Mar 26, 2009 01:28 PM
supracrx
Feb 17, 2008 09:06 AM
xstalkrx
Jun 29, 2004 08:03 PM
acuratech
Acura TL, RL & ZDX
11
Sep 12, 2003 08:31 PM
