cam seals
Old Mar 13, 2002 | 06:23 PM
out2wincrx's Avatar
Default cam seals
need to put cam seals in b16a just wonderiing the procedures and if any more parts are need to do this
Old Mar 13, 2002 | 06:51 PM
rainforest's Avatar
Default Re: cam seals (out2wincrx)
take off valve cove then pout them in then,cam seals then gasket sealer. no big deal.
Old Mar 13, 2002 | 08:20 PM
3rdGteg's Avatar
Default Re: cam seals (rainforest)
place timing belt at TDC--pull valve cover off--release tension on belt--slide belt off --pull cam gears off--remove seals--and replace everything back.
Old Mar 13, 2002 | 08:57 PM
LsTurbo91's Avatar
what he said!
Old Mar 13, 2002 | 09:50 PM
MrBite's Avatar
I have to replace the cam seal on my B18C1, is it the same procedure? I'm talking about the black rubber thing in this (crappy)pic, to the right of the VTEC solenoid:
I didn't think you'd have to take cam gears/timing belt off since it's on the other side...or are you guys talking about something else?
Old Mar 13, 2002 | 11:47 PM
Armed Ferret's Avatar
Default Re: cam seals (MrBite)
there's seals on both sides of the cams. if that's the one you're changing you're fine; you don't need to fvck with the timing belt/cam gears at all.
just make sure you torque everything down to spec when you're done.
EdGe(161)
Apr 11, 2011 09:28 AM
frankenstienEk
Jan 29, 2007 10:33 PM
4DRmafia
Dec 22, 2005 08:45 PM
mickey513
Jun 29, 2002 09:11 AM
