how do you measure piston to deck clearence??
Old Mar 15, 2002 | 06:07 PM
non-VTEC's Avatar
Default how do you measure piston to deck clearence??
just like the title says.............what tool(s) do you need to measure the piston to deck clearence? and how is it done?
thanks
Old Mar 15, 2002 | 06:31 PM
Sleeper's Avatar
Default Re: how do you measure piston to deck clearence?? (non-VTEC)
Install the #1 and #4 piston/rod assemblies in the block(w/crank and bearings of course), and put them at TDC(you dont need the rings to do this). Use a machininst scale or dial cal to mearsure the distance from the quench pad on the piston to the top of the cylinder, this is your piston to deck clr.
Old Mar 15, 2002 | 06:52 PM
non-VTEC's Avatar
Default Re: how do you measure piston to deck clearence?? (Sleeper)
the pistons have a dome to it. where is the quench pad? the very edge of the piston also have a small lip to it as you can see in the picture. do i measure from that small lip or the flat portion of the piston?
thanks
http://members.rogers.com/b20z/parts/pistontop1.jpg
Old Mar 16, 2002 | 05:38 AM
non-VTEC's Avatar
TTT
Old Mar 16, 2002 | 03:24 PM
Sleeper's Avatar
In your pic, look where the valve reliefs are cut and the flat top, on both the intake and exhaust side seperately. Measure from the lip or pad on these flats to the block top. Use which ever point is highest.
Old Mar 16, 2002 | 03:34 PM
non-VTEC's Avatar
great........thanks......
what if one piston is slightly higher than the other?
Old Mar 16, 2002 | 03:35 PM
rainforest's Avatar
quwnch pad is the part that is flat on the combustion chamber/piston where the air is mixed with the fuel.
[Modified by rainforest, 12:35 AM 3/17/2002]
ranta18
May 28, 2010 12:21 PM
itr_henrik
Jun 22, 2009 11:35 AM
D-SOHC 05
Oct 22, 2007 11:15 AM
98Psi ITR
Jan 26, 2002 08:52 PM
