How do you hook up a coolant temp gauge??? need help
Old Aug 19, 2003 | 07:19 PM
Eyewitness's Avatar
Default How do you hook up a coolant temp gauge??? not a stock one need help
ok the gauge in my cluster is fucked due to what seems to be electrical problems in the harness...so what is there out there i can rig up to tell how hot my engine is running and how hot my coolant temps are.....any help is appreciated...tia
Modified by Eyewitness at 8:52 PM 8/19/2003
Old Aug 19, 2003 | 10:59 PM
Jaesung's Avatar
if you follow the radiator hose, you should see a metal piece that sticks out, and it's about half an inch. use a flash light if you can't see it. the best advice would be to look under helms manual bc that's where i found it to be most helpful. good luck on the wiring. i had the same problem
Emilytcivic
Honda Civic (2006 - 2015)
Nov 22, 2014 04:54 AM
cpingor
Honda Civic (2001 - 2005)
Jun 7, 2011 11:24 PM
projekt90ef
Jan 19, 2010 03:43 PM
dkboyny11
Oct 23, 2005 03:13 PM
_Endless_
Mar 24, 2004 07:38 PM
