OBD0 CRX si ignition issues
Old Aug 18, 2003 | 11:27 AM
solorexer's Avatar
Default OBD0 CRX si ignition issues
for some reason, i have an intermitent ignition issue with my 89 CRX si. The only mods are a y8 exh. mani and a k/n filter. the car will start and run fine if the key is held to the start position and the starter is allowed to freewheel, but as soon as the key is turned to the "run" position, the motor dies. All fuses are ok, and all wiring harness connections are secure. I am thinking the ignition switch is bad, but before i replace it, i was wondering if anyone from this discussion forum has had a similiar problem, or has any other ideas. thanks for any input into this situation.
Old Aug 18, 2003 | 04:17 PM
XrcR6's Avatar
Default Re: OBD0 CRX si ignition issues (solorexer)
So when this happens the starter turns the flywheel, but is there actual ignitition/plugs firing? I remember every Civic from this generation had a recall on the igniter, was your's ever updated? Maybe that's going causing the intermittent starts...
Old Aug 18, 2003 | 05:33 PM
solorexer's Avatar
Default Re: OBD0 CRX si ignition issues (XrcR6)
The engine will run with the starter freewheeling when the key is turned to the start position. The engine idles, and will rev if I blip the throttle - in this case, the starter is turning, but is not engaging the flywheel. I have no idea if the igniter has ever been replaced, the car has 180k on it. I will call a couple of the honda dealerships areoud here and find out if they can replace it. Thanks for the help
Xynus
May 23, 2019 10:12 PM
Egalltheway
12
Jun 5, 2014 07:21 AM
3s0n3
15
Jan 3, 2013 02:14 PM
J.E.G.
Classic Hondas
Aug 31, 2009 01:27 AM
Mavrick
Mar 4, 2006 03:49 PM
