Oil Pressure Light
Old Aug 17, 2003 | 06:30 PM
SixPAK's Avatar
New User
Default Oil Pressure Light
On my friends jdm b18c motor, when he goes to start the car, the oil pressure light would stay on for a second or two after the engine starts. This only happens after the car has been sitting for a while, after the oil has settled into the pan again. Is this normal? He is using synthetic oil, 5w30 I think.
Old Aug 17, 2003 | 08:07 PM
chevyalltheway's Avatar
Default Re: Oil Pressure Light (SixPAK)
yes
Old Aug 17, 2003 | 08:30 PM
SixPAK's Avatar
New User
Default Re: Oil Pressure Light (chevyalltheway)
What causes this? I haven't seen it on other Honda's.
Old Aug 17, 2003 | 10:26 PM
HONDADNA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SixPAK &raquo;</TD></TR><TR><TD CLASS="quote">What causes this? I haven't seen it on other Honda's.</TD></TR></TABLE>
The firt two seconds are bulb check and if the light stays on then it indicates oil pressure lost. But yes it is normal. It is just a bulb check.
Old Aug 17, 2003 | 10:38 PM
SixPAK's Avatar
New User
Default Re: Oil Pressure Light (HONDADNA)
Ok...but when the car is warm and the oil hasn't settled, the light goes out right after the the engine starts. It's only when the car has been sitting that the light stays on (for a few seconds) AFTER the engine has started.
Old Aug 17, 2003 | 10:47 PM
mmuller's Avatar
Mad Scientist
check your oil pressure, it does that beacuse the system is taking longer to pressurize.maybe oil pump going bad
siis2fast
Nov 4, 2005 04:54 PM
PatrickGSR94
Dec 19, 2004 07:45 PM
PatrickGSR94
Dec 18, 2004 06:30 PM
kablamo
Jun 18, 2004 06:29 PM
