Early Shifting!
Old Aug 20, 2003 | 06:23 AM
KimChiKid's Avatar
Default Early Shifting!
I Just Got My B20Z In and running a P75 Ecu...I know that i could at least shift at 6200 without red-lining...but for some reason its making me shift at 5500 rpm's...anyone know why it would be doing this?...it wasn't doing this before and i am throwing a code 43...(fuel defective/malfunctoin)...but i don't believe that is the reason why my car is shifting early...anyone have any suggestions...?
Old Aug 20, 2003 | 07:56 AM
altoid's Avatar
Default Re: Early Shifting! (KimChiKid)
well you should believe it if you're car isn't getting fuel its not gunna go somewhere it can't, consider yourself loved, usually stupid actions reap stupid reactions, instead your car is waiting for you to squirt enough fuel in there before it will let you go upto that wild 6200
suggestion: fix it
Old Aug 20, 2003 | 08:24 AM
nate_d's Avatar
automatic?
Old Aug 20, 2003 | 05:43 PM
KimChiKid's Avatar
Default Re: Early Shifting! (d16eh2)
Manual of course why the hell would i have an Auto B20 swap?
Old Aug 20, 2003 | 06:38 PM
skud_dusty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KimChiKid &raquo;</TD></TR><TR><TD CLASS="quote">Manual of course why the hell would i have an Auto B20 swap?</TD></TR></TABLE>
well some people are dumbfucks, he thought that you could possibly be a dumbfuck, so he posted this
i'd figure out why the **** its throwing a code before you go revving the **** out of it.
Old Aug 21, 2003 | 03:32 PM
KimChiKid's Avatar
Default Re: Early Shifting! (skud_dusty)
I'm not revving the **** out of it...i dont want to **** up anything...so just chyll out!
Old Aug 21, 2003 | 07:21 PM
gitwidit's Avatar
troubleshoot in a helms manual for code 43. you figure it may have something to do with fuel pressure but it may just be in your ecu.
Old Aug 21, 2003 | 08:13 PM
PHiZ's Avatar
Default Re: Early Shifting! (GITWIDIT)
yeah, your description of the problem, almost made it sound like it might be an automatic?
So how exactly is it "forcing you" to shift? Rev limiting?
-PHiZ
Old Aug 23, 2003 | 04:47 PM
KimChiKid's Avatar
Default Re: Early Shifting! (PHiZ)
The limiter makes me shift early might be a realy?
Old Aug 23, 2003 | 08:02 PM
deepnite's Avatar
if u mean ur beginning to bog..did u change the fuel pump while doing the swap?
Old Aug 24, 2003 | 03:18 PM
KimChiKid's Avatar
Default Re: Early Shifting! (deepnite)
no bogging just the early shift with the limiter...no i didnt change the pump
Old Aug 24, 2003 | 04:26 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KimChiKid &raquo;</TD></TR><TR><TD CLASS="quote">it wasn't doing this before and i am throwing a code 43...(fuel defective/malfunctoin)...</TD></TR></TABLE>
What's your fuel presure?
Old Aug 29, 2003 | 09:21 AM
KimChiKid's Avatar
Default Re: Early Shifting! (Chiovnidca)
how do you check that out?
Old Aug 29, 2003 | 09:44 AM
tpr's Avatar
tpr
Does a big arm come out of the dash and make you shift or are you looking at a shift light and basing your shifts on that? Will it not rev above 5500 no matter how long you keep your foot in it?
Old Aug 29, 2003 | 01:52 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KimChiKid &raquo;</TD></TR><TR><TD CLASS="quote">how do you check that out?</TD></TR></TABLE>
With a fuel presure gauge.
Old Aug 30, 2003 | 06:40 AM
KimChiKid's Avatar
yes it keeps hitting the limiter...no stop talking about the limiter all you know is that it shifts early b/c of the MIL...i will check fuel pressure today thanks.
Old Sep 1, 2003 | 11:29 AM
KimChiKid's Avatar
Ok it reads at standard pressure should i have changed to a bigger fuel pump or sumthing?
Old Sep 3, 2003 | 04:14 AM
KimChiKid's Avatar
i DOnt know what To DO!
Old Sep 3, 2003 | 06:42 AM
MikeMAN's Avatar
get an adjustable FPR, set it at 50psi, enjoy your b20vtec
Old Sep 6, 2003 | 04:00 PM
KimChiKid's Avatar
Default Re: Early Shifting! (MikeMAN)
Ummm i don't have b20 vtec guy
Old Sep 6, 2003 | 06:32 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KimChiKid &raquo;</TD></TR><TR><TD CLASS="quote">Ok it reads at standard pressure should i have changed to a bigger fuel pump or sumthing? </TD></TR></TABLE>
Does the fuel presure drop off at higher RPMs under load?
efbastard
Feb 13, 2017 06:31 PM
Lambo123
21
Nov 18, 2016 09:11 PM
Jlamar757
May 25, 2006 03:16 PM
DieMaster
13
Aug 31, 2004 10:45 AM
civic dx
17
May 12, 2002 02:50 AM
