pieceing together a turbo kit?
i have a 99 civic ex. i want to put a turbo on it. i have already bought a t3/t4 turbo, turbo manifold and down pipe, piping that runs to the intercooler, intercooler. i need to know what i need to make this work.
i also don't really understand how to set it all up. on the manifold the is a little pipe comeing off the side what goes there.
the pipe coming off the manifold is for an external wastegate. you will also need your oil feed/return lines, vacuum tubing, a blow off valve, larger injectors, possibly an SMC or S-afc or hondata to idle the larger injectors (i have a friend running vtec lude injectors that are 310's with no problems, but those might not flow enough for your demands with a turbo that big)...and if you dont get a hondata a MSD BTM would be a very good idea...
It's on the main honda-tech page...its the fourth one down under the technical forums
And if your that new welcome to the board...WELCOME!
Another hint...there is a link called search in the top right of the page. Click that and type in your question and click the archived information. You'll find all kinds of sruff on this subject.
alexg103
Mid-Atlantic (Sales)
Jun 22, 2009 02:36 PM
alexg103
Jun 22, 2009 02:35 PM
