keep blowing fuses, what's the problem!?!
Old Aug 16, 2003 | 10:52 PM
crx1856's Avatar
Default keep blowing fuses, what's the problem!?!
i can't get a fuse in my tail light instrument fuse holder under my dash without it blowing as soon as the fuse makes contact. i tried disconecting my battery and installing the fuse but it blows when i conect the battery. i disconnected everything i installed recently but it still won't hold a fuse. what does this mean. all my other fuses work fine.
Old Aug 17, 2003 | 08:45 AM
EX-T's Avatar
Default Re: keep blowing fuses, what's the problem!?! (crx1856)
something is grounding out...what did you do? did you splice into any wires associated with that fuse?
Old Aug 17, 2003 | 12:11 PM
jcda6's Avatar
Make sure you're reading the fuse diagram correctly. Perhaps you replaced one or more fuses with the wrong ampage. Also, like the guys said above me, check your grounds, you're shorting out somewhere.
-Jeff C.
Old Aug 17, 2003 | 04:25 PM
crx1856's Avatar
Default Re: keep blowing fuses, what's the problem!?! (jcda6)
as it turns out, it was a wire from my stereo adapter shorting out the fuse. i did a search and found the exact awnser to my problem. can you imagine that? for honda-tech
Old Aug 17, 2003 | 04:28 PM
EX-T's Avatar
at least the search button works for you.... ::shrugs::
dhealey
Honda CR-V & Element
11
Jun 5, 2024 06:31 PM
LUDE21
May 31, 2007 01:52 PM
Sic_DA_Nine
Audio / Security / Video
Jan 7, 2007 11:04 AM
merch1
Mar 6, 2005 11:07 AM
ModlesSI
Feb 22, 2003 03:16 PM
