DOHC valve adjustment ???'s
Old Aug 17, 2003 | 06:29 AM
Soled Out's Avatar
Default DOHC valve adjustment ???'s
I was reading in my manual for my car and it says that you have to use a special tool for doing an adjustment on a DOHC for the lock nuts and screw. Now ive done valve adjustments on motorcycles/4 wheelers and i always just used a boxed end wrnech and a screwdriver and tightened/loosened. So my first question is do i need this tool or can i just use a screwdriver/wrench? And my second question, i heard that you HAVE to let your motor cool for a good 3 hours to over night before you do an adjustment...is this true or can i just go right outside and do it? I also heard if you adjust them to have a higher lift it'l squeeze a little more power out of it, so would you ajdust it to a lower # like .17 or .20 for a higher lift?Thanks.
Modified by Gray EG at 10:43 AM 8/17/2003
Old Aug 17, 2003 | 07:38 AM
owen_the_soyboy's Avatar
Default Re: DOHC valve adjustment ???'s (Gray EG)
it HAS to be cool to be done correctly.
you can use a box-end wrench and bend it to the shape required with heat from a torch, or you can use a deep socket and a pair of vice grips to hold the socket while wticking a screwdriver thru the socket. I welded a deep socket onto an old wrench and it works but I should have used a VERY deep socket.
adjust to a higher lift? you are only adjusting the gap.... my guess is the lower number in the tolerance range will be a tigher fit and leave less room for slop in the valves movement, but I havent heard any tricks or anything, only to be sure and use stock adjustment specs.
Old Aug 17, 2003 | 09:32 AM
Soled Out's Avatar
Default Re: DOHC valve adjustment ???'s (owen_the_soyboy)
Thanks owen
jordy478
Aug 7, 2012 08:47 PM
redDAinteg
Oct 24, 2005 02:22 PM
KOALA YUMMIES
Jul 20, 2004 06:23 AM
NXSpoon
Jun 8, 2002 10:16 AM
speedymon
Jan 15, 2002 01:09 PM
