pieceing together a turbo hit?
Old Aug 20, 2003 | 12:19 PM
napester21's Avatar
Default pieceing together a turbo hit?
i have a 99 civic ex. i want to put a turbo on it. i have already bought a t3/t4 turbo, turbo manifold and down pipe, piping that runs to the intercooler, intercooler. i need to know what i need to make this work.
i also don't really understand how to set it all up. on the manifold the is a little pipe comeing off the side what goes there.
Old Aug 20, 2003 | 03:48 PM
turbod96ex's Avatar
Default Re: pieceing together a turbo hit? (napester21)
Hey I just built a turbo kit and ran it today. What a hassle. It took a long time to get going. That thing on the side of the manifold is where the waste gate goes. Depending on its size(find that out) you need to get a waste gate. You can get the cheap one Delta gate but I highly recomend getting a Tial wastegate. I ran a delta gate and it had boost spikes blowing my head gasket. YOu will also need to run the oiling system. This I found was the hardest part. You need to put the turbo on and togeather, and see where the oil return would hook up on the oil pan. Then you need to tap the oil pan (take it off first) and hook up the oil return. I found it nearly impossible to find the right pipe tap for the return. You will need to buy some sort of return. Ebay has tons of them for sale. The oil inlet is a lot easyier. Right above where your oil filter sits is the oil sending unit. Take that off and put in a t fitting. easy to find in home depot. Then you have tons of intercooler lines to run. Good luck. Tell me what parts you bought spicificly and I can be of more help
Old Aug 20, 2003 | 10:18 PM
napester21's Avatar
Default Re: pieceing together a turbo hit? (turbod96ex)
ok exact parts are( t3/t4 turbo .50 a/r 500 whp 57t ,piping set wtih the intercooler pipes are custom but made with the plans off the greedy turbo pipes, the intercooler is a truse of some thing like that it handles 35psi (fmi)
littleblue
Jan 9, 2006 03:35 PM
OG SHG_EM1
Mar 28, 2004 09:10 PM
1flossedteg
May 26, 2002 09:39 PM
89 CRX SI
Apr 6, 2002 07:56 AM
Audipwr1
Mar 19, 2002 08:30 AM
