Do all B-series use the same oil filter?
Old Aug 19, 2003 | 01:07 PM
nolimits's Avatar
Default Do all B-series use the same oil filter?
Is the same oil filter used throught the entire B-series line-up. More specifically I'm looking at purchasing some oem filters in bulk on ebay and want to make sure that I don't end up with a bunch of filters I can't use!! I have a 97 JDM ITR B18C. Anyone have the correct part numbers?
Old Aug 19, 2003 | 01:18 PM
Regular Series's Avatar
Default Re: Do all B-series use the same oil filter? (nolimits)
I'm pretty sure Honda only uses one size oil filter for all of their engines.
Old Aug 19, 2003 | 01:21 PM
4DeepCivic's Avatar
Default Re: Do all B-series use the same oil filter? (Regular Series)
It even fits 92-00 civics also. I use the same filter on my Integra, B16 Civic, and my mom's 00 civic lx.
Old Aug 19, 2003 | 01:41 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nolimits &raquo;</TD></TR><TR><TD CLASS="quote">Is the same oil filter used throught the entire B-series line-up. More specifically I'm looking at purchasing some oem filters in bulk on ebay and want to make sure that I don't end up with a bunch of filters I can't use!! I have a 97 JDM ITR B18C. Anyone have the correct part numbers?</TD></TR></TABLE>
Yes, even H and F series use the same.
Old Aug 19, 2003 | 04:20 PM
mattdyeatl's Avatar
Yes they do Matt
Old Aug 19, 2003 | 06:36 PM
GumballNA's Avatar
well not ALL their engines... i believe...90's and up they were mostly the same, except for some of the motors in the acura, and of coarse the new K-series is not the same.
but as for b-series yes they are all the same.
Old Aug 19, 2003 | 11:46 PM
camp1320.com's Avatar
Default Re: Do all B-series use the same oil filter? (Type-X)
You are correct .. all 90-00 4 cyl honda use the same oil filter. the new K series has a smaller filter. i was wondering if that created more oil presurre. I will research and let you guys know.
Old Aug 20, 2003 | 01:36 AM
ill phil's Avatar
Default Re: Do all B-series use the same oil filter? (camp1320.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camp1320.com &raquo;</TD></TR><TR><TD CLASS="quote"> the new K series has a smaller filter. i was wondering if that created more oil presurre. I will research and let you guys know.</TD></TR></TABLE>
I've heard numerous rumors about that as well, but nothing solid. Maybe I haven't researched enough
Old Aug 20, 2003 | 02:28 AM
eg_type_r93's Avatar
Default Re: Do all B-series use the same oil filter? (ill phil)
thought the k series were bigger ? (filters)
Old Aug 20, 2003 | 04:55 AM
JimBlake's Avatar
Default Re: Do all B-series use the same oil filter? (eg_type_r93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_type_r93 &raquo;</TD></TR><TR><TD CLASS="quote">thought the k series were bigger ? (filters) </TD></TR></TABLE>The new filters are smaller in diameter, about the same length. Same base, thread, & gasket. The new filters fit on the old engines, but the bigger old filters don't fit on the K engines. There's something in the way...
There's a couple orphans with different filters, like the Passport. Which is really an Isuzu anyway...
Old Aug 20, 2003 | 09:24 AM
rsbad454's Avatar
Default Re: Do all B-series use the same oil filter? (JimBlake)
i hard K Seires is smaller as well, but will fit Bseries..........means more pressure.
Old Aug 20, 2003 | 09:44 AM
JDMHN8's Avatar
Default Re: Do all B-series use the same oil filter? (rsbad454)
Insights use very tiny Toyo Roki filters that have the same inlet and gasket diameter as a B-series. Might be a good choice for an engine break in.
Old Aug 20, 2003 | 09:51 AM
AudioXtremes's Avatar
Default Re: Do all B-series use the same oil filter? (JDMDA9)
are d series the same as well?
Old Aug 20, 2003 | 10:49 AM
ill phil's Avatar
Default Re: Do all B-series use the same oil filter? (AudioXtremes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AudioXtremes &raquo;</TD></TR><TR><TD CLASS="quote">are d series the same as well?</TD></TR></TABLE>
Read the whole post
Old Aug 20, 2003 | 11:27 AM
Doctor CorteZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camp1320.com &raquo;</TD></TR><TR><TD CLASS="quote"> i was wondering if that created more oil presurre. I will research and let you guys know.</TD></TR></TABLE>
yes , it does.
rumored at 20psi more under WOT.
why you think you need more oil pressure is beyond me though
b18 hatch mike
Apr 24, 2008 08:32 PM
eL
Honda Civic (2006 - 2015)
Jan 7, 2007 06:17 PM
rehab_this
Acura TL, RL & ZDX
Nov 5, 2006 03:21 AM
philosofy1
12
Sep 29, 2005 06:24 AM
pezzy
Jun 27, 2004 03:40 PM
