signs of bad head gasket???
Old Aug 16, 2003 | 06:27 PM
bubbajim's Avatar
Default signs of bad head gasket???
im having to put about 500ml of water every week in my rad, blown head gasket???????????
Old Aug 16, 2003 | 06:35 PM
Stripped Honda's Avatar
99-0104
Default Re: signs of bad head gasket??? (bubbajim)
you need to find the sorce of the leak .... it could be a hose or bad water pump run a pressure test and also just as a quick check open your oil cap and if it has a tanish brown substance on it then you most likely have a blown headgasket if it doesent then i say you just have a water leak .. good luck do the test and let us know....
Old Aug 16, 2003 | 07:22 PM
HONDADNA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bubbajim &raquo;</TD></TR><TR><TD CLASS="quote">im having to put about 500ml of water every week in my rad, blown head gasket???????????</TD></TR></TABLE>
1) hard starting
2) overheating
3) rought idle
4) low compression
5) white smoke out of the tail pipe
6) brownish color when mixed with oil
7) greenish color on the tip of spark plugs
Hope this is some help
Old Aug 16, 2003 | 07:47 PM
bubbajim's Avatar
Default Re: signs of bad head gasket??? (HONDADNA)
im not getting any of those symptoms, but i have seen some little dirty specs floating in my over-flow bottle.
Old Aug 16, 2003 | 07:48 PM
bubbajim's Avatar
and its a new rad.
Old Aug 16, 2003 | 09:50 PM
HONDADNA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bubbajim &raquo;</TD></TR><TR><TD CLASS="quote">im not getting any of those symptoms, but i have seen some little dirty specs floating in my over-flow bottle.</TD></TR></TABLE>
You should do a cooling system pressure test and check for external leakage. The best to use to look for an external coolant leak is a LED UV light. The UV light will reflect the green color of the coolant like glowing green light. You also use a LED pen light with a blue LED light. This tool can be purchase at Napa for about $20.00 or at toolwarehouse.net.
Old Aug 17, 2003 | 10:32 AM
bubbajim's Avatar
thanks alot man.
Old Aug 17, 2003 | 11:57 AM
jcda6's Avatar
I can't remember what the additive is called, but it is found in the local parts store. Comes in a small bottle, brown in color. Add into radiator, start the car up and use a black light or LED pen light and look for leak. It will appear whitish, and locate the leak source.
-Jeff C.
Old Aug 17, 2003 | 09:50 PM
HONDADNA's Avatar
Default Re: signs of bad head gasket??? (jcda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jcda6 &raquo;</TD></TR><TR><TD CLASS="quote">I can't remember what the additive is called, but it is found in the local parts store. Comes in a small bottle, brown in color. Add into radiator, start the car up and use a black light or LED pen light and look for leak. It will appear whitish, and locate the leak source.
-Jeff C.</TD></TR></TABLE>
I also don't remember the name. but, it dye in it to trace coolant leak. but, you will still need to buy a uv light, alot of money. The dye stuff is better for Toyota; for, they use a red type of coolant. But, the blue LED works get on tracing coolant. The blue light reflects the green coolant and make it stand out alot. You should try it - the LED pen light only cost about $10 - $20 dollars. A local Napa store should have this tool or any place that sells tools. However, you can purchase it also at http://www.toolwarehouse.net.
jackfast
Mar 23, 2009 07:32 AM
cehcivic15
Jan 1, 2009 05:21 PM
djviet2000
23
Apr 29, 2008 09:36 PM
zcmotor
29
Apr 18, 2008 10:20 AM
93baggedcivic
28
Dec 24, 2007 09:42 AM
