no compression..car bogs below 2k
Old Aug 17, 2003 | 07:29 PM
PA MATT's Avatar
Default no compression..car bogs below 2k
well i broke my timing belt and i fixed that,did water pump and adjusted the valves. my car bogs down below 2k but is fine above that.
i'm wonderin if this because i possibly have bent valves or if it could be the valves are just tightened too much?
Old Aug 18, 2003 | 03:15 AM
PA MATT's Avatar
Default Re: no compression..car bogs below 2k (ebpG2)
bump
Old Aug 18, 2003 | 06:01 AM
4DeepCivic's Avatar
Check compression.
Old Aug 18, 2003 | 09:56 AM
PA MATT's Avatar
Default Re: no compression..car bogs below 2k (4DeepCivic)
i checked compression and it came out 170, 150, 150, 170. Not bad for a 91 LS. any ideas what it could be? I'm thinkin i may be one tooth off which is causin it to bog down so bad
Old Aug 18, 2003 | 10:04 AM
nate_d's Avatar
yea your timing may be off, or like you said, its possible for you to be a tooth off.
Old Aug 18, 2003 | 10:37 AM
PA MATT's Avatar
Default Re: no compression..car bogs below 2k (d16eh2)
i'm gonna check my timing tonite....do you think its possible this could be caused by valves being too tight?also, after takin my car around the block no smoke comes out the exhaust but when i pop the hood there is tons of smoke. I'm not sure if this is from oil gettin on the block when i did the timing belt or what it could be from
BONNARSKI
Dec 21, 2011 09:26 PM
99integralsboy
Jan 22, 2008 02:44 PM
DC2_ALL MOTA
Dec 5, 2007 03:00 PM
93egsi
15
Dec 28, 2004 11:26 AM
AK94GSR
May 10, 2002 09:39 AM
