Differential Free spins
Old May 4, 2004 | 04:38 PM
Apollo's Avatar
Default Differential Free spins
I was wondering if anybody had any idea if a d16a6 has a pin that runs through the differential gear that ends up driving the axles.
What happened was i was going around a corner and it just stopped moving, no noise, no catching. I have all gears so it is not a select fork in the tran. The differential is also spinning because the speedometer is run off from the diff. and it moves normally.
Any information would be appreciated.
Old May 4, 2004 | 04:57 PM
Chiovnidca's Avatar
Default Re: Differential Free spins (Apollo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apollo &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if anybody had any idea if a d16a6 has a pin that runs through the differential gear that ends up driving the axles.
Any information would be appreciated. </TD></TR></TABLE>
A differential will usually make a good bit of noise when it gets to the point the car wont move. I'd take a close look at the axles.
Old May 4, 2004 | 05:14 PM
Kamin's Avatar
Default Re: Differential Free spins (Chiovnidca)
Yes. you probably destroied a joint inside an axle. if your differental broke you would know it.
darkwater_ghost
Transmission & Drivetrain
Jan 3, 2013 11:31 AM
silverboost
Feb 10, 2007 11:30 AM
wrestler72
May 14, 2006 03:57 PM
shai x boi racer
11
Oct 20, 2005 05:54 PM
philgood
10
Mar 23, 2004 06:35 PM
