eradic idle...HELP
Old May 6, 2004 | 09:45 PM
zickyicky's Avatar
Default eradic idle...HELP
my 95 integra ls idles eradically....any ideas?
Old May 7, 2004 | 04:27 AM
JimBlake's Avatar
Default Re: eradic idle...HELP (zickyicky)
That's not much information... How's your normal tune-up stuff? Does the idle speed surge up & down? Every few seconds or how fast? Or does it misfire a lot & stumble? Describe what it's doing.
It could be as easy as a tune-up. Old plugs, bad plug wires, arcing across the distributor cap... If that stuff's good, then check/clean your IAC valve.
Old May 7, 2004 | 08:30 AM
dohcter g's Avatar
I bet It is a vaccum leak or Intake mani gasket!!!!
Old May 7, 2004 | 09:56 AM
zickyicky's Avatar
Default Re: eradic idle...HELP (JimBlake)
yea...the idle surges up and down constantly. If i let the car idle and warm up for about 5 min the surging stops and it settles at a high rpm(around 2000rpm). but, it starts doing it again as soon as i touch the gas pedal and let off. i have new plugs and new wires as well as a new iac valve.........
dointhemzs
Sep 7, 2008 07:09 PM
stephane613
Jan 19, 2008 06:53 PM
MS99k
Feb 27, 2005 01:33 PM
Accord88
Feb 23, 2003 05:53 AM
ArchAngel Sabastian
Sep 11, 2002 09:29 PM
