how to wire check engine light?
Old May 4, 2004 | 07:56 PM
95LSDOHC's Avatar
Default how to wire check engine light?
ok fellas....got a Q for ya.....my buddy is wondering if any of you guys knew how to wire up a check engine light...he tried hooking up a light bulb to it by grounding one side and using the positive side as the signal for the check engine wire on his ecu (this was just a shot in the dark) but it was a no go. any help is appreciated
Old May 4, 2004 | 08:36 PM
95LSDOHC's Avatar
Default Re: how to wire check engine light? (95LSDOHC)
nobody has any ideas....hes trying really hard to get this car running right (240sx with a 2jz in it )....any help is appreciated
Old May 5, 2004 | 05:17 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95LSDOHC &raquo;</TD></TR><TR><TD CLASS="quote">... (240sx with a 2jz in it )...</TD></TR></TABLE>He might want to get his hands on a circuit drawing for Nissan... Maybe the lamp has constant +12v & the ECU closes the ground side of the circuit to turn it on??
Old May 5, 2004 | 05:32 PM
95240sx2jz's Avatar
Default Re: how to wire check engine light? (JimBlake)
hey thanks jim for the suggestion...thats what it thought too but i ended up figurin it out, it gets its voltage from the wire that runs to the alternator and then has to tap into to other wires...i was a dumbass and neglected to look at the huge wiring diagram i have in my basement...thanks for the help
Dane
Old May 5, 2004 | 09:43 PM
PeteySchrilla's Avatar
use a paper clip
SH
Sep 30, 2007 12:47 PM
SleeperGSR
Jul 15, 2007 10:05 AM
Al-sonic
Jan 9, 2007 08:29 PM
soon2b
May 22, 2005 06:39 AM
